Question about Dacor ECS130 Epicure Electric Single Oven
Error codes on my Dacor Range -
Water splashed on the stove and it started with a f1 code then a f0 code. It was beeping nonstop - so I shut the circut breaker off to see if it would reset. Instead it started showing a 080 or 075 code but no longer the clock. Any advice?
  • Anonymous Oct 15, 2008
    we spilled a little milk on the oven and it is beeping non-stop and flashing F-1.
  • 175 Answers
Both of those codes suggest a bad membrane switch assembly. i dont specifically remember what the f1 error is, but the f0 error is "stuck membrane button" The membrane switch is just the touch panel, and usually run in the mid $200 range for the part. Its fairly easy to change, just label all your wires when you pull em off so you know what direction they go in. some of the connectors CAN BE put on backwards, so just make a good diagram or whatever to get em right. Good luck!
Posted on Jun 18, 2007
SOURCE:
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping sound
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Mar 22, 2008 | GE JKP28 Electric Double Oven
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Dacor ECS130 Epicure Electric Single Oven Logo
1,189 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
