Question about Microsoft Windows 98 for PC
In the middle of installing Windows 98 in Virtualbox I get a message Application Error SUWIN caused an Illegal Instruction in module VGA.DRV at 0001:011B. How can I fix this error?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Is this occuring during the install?
If this is the case, try this (it will be useful to know when the problem occurs):
Go to the VM Settings
Go to System
Go to Acceleration Tab
Uncheck Enable VT x AMD V
I hope that helps.
If not, there is a guide on the virtualbox forums here
Which I would suggest trying to run through instead.
Posted on Dec 23, 2012
    New Friend:
I had a similar error:
SUWIN caused ******* instructions module unknown
Once I disabled (removed check) on the Hardware Virtualization box for "Enable VT-x/AMD-v; and changed Paravirtualization Interface to 'None' the setup moved forward. But, I needed to Change the ParaVirtualization setting back to Default so it would boot up.
VirtualBox version 5.0.18
Posted on Apr 27, 2016
  • 2692 Answers
SOURCE: the ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Posted on Dec 27, 2008
hardwhere
  • 13 Answers
SOURCE: ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
Posted on Jan 18, 2009
wykidtech
  • 99 Answers
SOURCE: Microsoft Windows Vista Home Premium
Basically, your error comes from a program that may not be compatible with Vista. Would you mind listing the software that was installed on the computer?
  • First, update the using Windows update, if you never updated the PC, this may take a minute.
  • When you computer comes on, press F2, F4, or Esc key to go into setup. You PC will tell you which button to press, you have to look quickly.
  • There should be an option for memory, it will tell you what is installed.
  • When the computer is updated, see if the error comes up.
For the video card, does your card have a port similar to this:
Then you need a DVI cable, which is an inexpensive cable you can pick up at Radio Shack.
Posted on Mar 21, 2009
rtrahan
  • 741 Answers
SOURCE: 16 bit MS DOS Subsystem error
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Posted on Apr 13, 2009
SOURCE: Explorer.exe Application error in Windows XP Professional SP2
i think you must to format it with the good cd windows because the problem is has an error while installing windows. thx
Posted on Sep 19, 2009
The ntvdm cpu has endountered an illegal instruction. Cs:0df1 IPL01f6 OP: ff ff 00 00 ff
SYMPTOMS
When you attempt to run a 16-bit program on a computer running Microsoft Windows NT 4.0 Service Pack 3, the program may quit immediately, or you may receive the following error message:
Hidden Console of WOW VDM
The NTVDM CPU has encountered an illegal instruction.
CS: 04c3 IP:3937 OP:c71c 9d 37 00
Choose Close to terminate the application.
When you click Close, you may receive several similar error messages.
CAUSE
This behavior can occur if you use an incorrect version of the Command.com file. For example, this issue is known to occur if you use a Command.com file included in Microsoft Windows 95, dated 7/11/95.
RESOLUTION
To resolve this issue, replace the Command.com file in the Winnt\System32 folder with the same file from another computer that is running Windows NT Workstation 4.0 or Windows NT Server 4.0, and then make sure that there are no Command.com files dated 7/11/95 on the computer. You can also replace the Command.com file on the computer with the same file on the Windows NT installation CD-ROM.
PROPERTIES
Article ID: 245184 - Last Review: November 1, 2006 - Revision: 1.1
APPLIES TO
Microsoft Windows NT Server 4.0 Standard Edition
Microsoft Windows NT Workstation 4.0 Developer Edition
Jul 22, 2014 | Dell Computers & Internet
I am trying to install Titanic: Adventure out of Time for Windows 98. My computer currently has Windows Vista. I keep getting the following errors while trying to install the gam: this file does not...
Welcome to Fixya. The problem that you have occurs because the program or application that you are trying to install is not compatible with windows vista. The game was released before the release of windows vista or even xp that's why it is not working. You can check the maker of the game and see if they release the patch for the windows vista version if not then there's no way you can play it on your system.
Thanks
Aug 31, 2011 | Cyberflix Video Game Consoles & Games
Ntvdm cpu encountered illegal operation Hi all! I just installed Maya 2010 from a torrent file and since then I got this famous error message. It's just appeears as three command prompts appearing at the...
If I am reading this right your issue is not the application but where you obtained the application. Maya 2010 is a modern design application and comes in 32 & 64 bit versions. It is not a 16 bit application.
When Windows encounters a legacy application it calls the NTVDM for the legacy application to run in.
The fact that the application is calling the NTVDM is highly suspicious. NTVDM is the NT Virtual Dos Machine, a way for legacy applications to run in NT environments.
NT environments are Windows NT 3.5, NT 4.0, Windows 2000 Professional, Windows XP (Home, Pro & Media Center Ed), Vista (all versions) and Windows 7.
Old (legacy) applications written for 16 bit date back to Windows 3.1 and include Windows 95, 98 and Millennium Edition.
I would obtain a copy of Maya 2010 from a reputable outlet instead of Bit Torrent as "warez" frequently contain malicious items that will infect and ruin your machine.
Feb 05, 2010 | Microsoft Windows XP Home Edition
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Apr 13, 2009 | Microsoft Windows XP Home Edition
Start menu wont show up
application softwares &system software in start menu
Feb 02, 2009 | Microsoft Windows 98 for PC
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
Driver installation problem
Firstly uninstall the drivers u already have. The file imf16.drv is corrupted, so u need to install from different cd, if u do not have another on try this site for download, u must choose the drivers for windows 98.
click on the link below:
http://www.driverstock.com/HP-LaserJet-1020-driver-download/10-26-2954/index.html
Mar 01, 2008 | HP LaserJet 1020 Printer
Illegal Operation
Hi, sounds like you might have a faulty part in the pc, ie memory or hard drive etc. if you have already installed windows from scratch on the pc and your still getting these faults i would say its the memory or hard drive is faulty..
Have a good new year
John
Dec 29, 2007 | Compaq Armada E500 Notebook
Microsoft Windows 98 for PC Logo
1,525 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
