Question about SanDisk Sansa Clip MP3 Player
SanDisk 4G displays memory free error then shuts off
SanDisk 4G work fine with loaded e-books.
Plugged it in a USB port on a Linux machine to charge battery.
After disconnecting, display shows "Not enough space for Music DB.
Please free 30MB"
It then shuts off.
thanks
  • hook96 Jan 17, 2009
    Power button reset has no effect
    Can't remove battery. Have no idea how to take it apart.
    "Sansa Clip Overview' says the rechargeable batteries are no replaceable, which leads me to
    believe that they(or it) is solder in place.
    Did manage to remove the plastic 'clip'.
    thanks
    believe that they(or it) is soldered in place.
    thanks
    President:
  • 948 Answers
Slide and hold the power switch up for about 20 seconds to reset the player. Then power on the unit. If the error is still there, connect the unit to your computer and attempt to save all of your files so you can reformat. I would also upgrade the firmware if you don't have the latest.
Posted on Jan 17, 2009
  • 340 Answers
Hi Dr. Hook
Did you mount the scandisk? The Linux machine might have mounted it and when you just remove it, then some software still stay on the scandisk. Insert the scandisk into the Linux machine again and umount it (unmount). Then plug it into a real computer :-), find the drive and look indside to find and delet what you dont need.
Regards /Teis
  • SanDisk Master
  • 6,487 Answers
If you can try to connect this device to a windows computer and hopefully it will be recognize then when its recognize you can already format the unit and that should fix the problem...
  • 11,896 Answers
Plug your SanDisk back in the usb port. Then go to my computer, find the drive that contains your SanDiisk. Open the drive and see what is installed. Remove anything that you didn't personally place there. Sometimes by just connecting the device your computer might have installed files by default Or your player didn't recognize how much space it really had until you plugged and it updated itself.
    Genius:
  • 1,199 Answers
I would try resetting it ! you will not lose anything!
let me know if this does it!
Push reset button with a pin!
    Scholar:
  • 160 Answers
Remove the battery and reinsert it to reset the device first and check wether the message goes away.
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Your new hardware might not work properly error will appears
This error message comes up when you plugged in your USB Flash drive into a lower version of a USB port. Try using another port in your machine, ports that are USB 2.0 compatible and you shouldn't see this error again.
By the way, there are old motherboards which does not have ports for USB 2.0. You might want to check your motherboard user guide and see which ports runs at 2.0. If there is none, I'm afraid that the only way around it is to upgrade into a better motherboard.
Hope this help.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to find Sandisk cruzer 4G USB drive serial number? Embeded serial number how to find
Try using Belarc Advisor with the USB drive plugged in. Read the report to get the serial number. Hope this helps.
Mar 14, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Was Dragging Files Onto My 2GB Flash Drive And It Stopped Working
This story may give you hope.
This very same day, I removed my Cruzer Micro unsafely and it stopped being recognized by the computer. I plugged it into another USB port and it did not work. I tried to access it under Ubuntu Linux: I could see the drive but if I click on its icon, I get the message Unable to mount volume, no media.
I tried to reinstall the SanDisk LaunchPad, but it refused to be coaxed because it did not recognize the drive as a SanDisk.
I mourned may drive, but still had hope to recover my data. A google search took me to some data recovery company, that would charge close to 300 dollars. I had no intention of paying that kind of money.
Then, without any particular reason, I plugged the drive in a USB hub that I connected to one of the two ports that failed to recognize the drive. And the miracle happened. Windows recognized it. Was it the presence of the Hub? I don't know.
I made haste to transfer my data to a folder in my computer.
After the transfer I installed the LaunchPad I downlowed from SanDisk. It warned me that my files will be lost. But since I already transferred them, I could not care less.
When I reaccessed the drive, my files were still there. Now my drive works fine: it is recognized by Windows, as well as Ubuntu.
The moral of this story is don't give up easily, and keep trying.
What do you think?
Aug 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My SanDisk 2GB USB just stopped working whilst I was typing
pls try to connect this usb drive to a linux machine and see what u get? let me know if you get ur data back :-)
Aug 21, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I plug my sandisk into the computer, I can't find it-but if I plug memory stick into same plug I can find it. How come my computer is not recongizing the sandisk
i was having the same issue, the usb port i was using was in the front of my pc, it wasn't recognizing it.. i plugged it into one of the usb ports in the back of the pc and now it seems to be working fine... hope this helps
Jul 25, 2009 | SanDisk Sansa e260 MP3 Player
Printer won't work because I plugged into it a SanDisk.
I was told to unplug it, since the printer would not respond. That worked! It reset itself when I plugged it back in and turned it on. Thank you.
Apr 17, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
CHARGING A 1 DAY USED SANDISK SANSA MP3 4G
Run the Sansa Recovery Tool from Sandisks' website and start over from scratch. Usually this problem is caused by trying to transfer too many songs at once, but any number of Rhapsody errors could have caused this.
-Tha Mp3 Doctor
Nov 30, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk multi card reader
if you are using a cord and usb port it sounds like your usb port is loose and not holding on. Try plugging it into another port maybe on the back of your computer.
Let me know if this works
Dec 14, 2007 | SanDisk MobileMate SD Plus 5-in-1 Media...
SanDisk Sansa Clip MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
