Question about HP LaserJet 3700n Printer
Transfer unit hi all I have a color laserjet 3700,it keeps giving me the message install transfer unit,i replaced tranfer unit and still got same message also reset unit setting,all contacts are touching,i have no manual for this unit ,so i dont know where all of the sensor are located for the transfer unit,if there is a service manual or if any one can help please do and thanks a lot.
    Genius:
  • 2,120 Answers
You need to reset the counter, instructions should have been in the box.
Posted on Jan 16, 2009
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Apr 11, 2011 | HP LaserJet 4700 Printer
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
My 4700dn is giving me the replace transfer kit message. I have swapped out known good transfer kits and the printer prints fine but I still get the replace transfer kit message. What can I try next?
The message only clears when you install a new transfer unit, one that hasn't been used before. If you want to clear the message, you'll have to install a brand new transfer belt.
If you know the service PIN for the 4700, you can probably go into the service menu and clear the message, but otherwise a new transfer unit is the only way to go.
Aug 11, 2010 | HP LaserJet 4700 Printer
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
missing or incorrectly
installed. Ensure that the
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
I have a HP color laserjet 4650dn that when you print a document, there are pink spots all throughout the document. Is this due to replacing the fuser or transfer bar? There are no warning indications on...
It depends on the true color of the spots. If what you describe as pink are actually Magenta colored spots then I would suspect the Magenta toner/drum cartridge. It is definately not the fuser. The transfer bar or actually transfer belt unit in this case is doubtful to be the cause. A defect in the tranfer belt unit does not normally show up as 1 color. It is usally multiple colors. I would open the front cover and at least visually inspect the Magenta toner cartridge. If you have a spare unit, even an old one to swap it out with even better. Look at the color of the Magenta toner and compare it to the spots you are seeing. If they are similar then in my opinion the problem is in the Magenta drum unit.
Apr 21, 2010 | HP Color LaserJet 4650DTN Printer
Keep getting the message "replace Transfer Kit". Took a good one from another unit, but still get the message.
You need to buy a new one as they have electronic chips on them which reset the counts hope this helps.
Aug 10, 2009 | HP LaserJet 3700 Printer
Not sure which part that may need to be replace
tranfer belt is a large mylar black belt.
transfer roller is a skinny gray foam roller
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Transfer kit
The transfer kit is unrelated to the toner. On most printers it gives you the message that it needs replaced after X number of prints. Depending on page coverage and the quality of the paper you are using there may still be some life in it and you can clear the message and print until the image quality is affected then change it.
May 29, 2008 | HP LaserJet 4600dn Color Printer
59.0A error in hp color laserjet 3700
All 59.XX error codes have to do with a motor failure of some type. I don't know anything specific about 59.0A but 59.A0 means that either the drum motor failed to start or something bad happened while it was rotating. If you feel like tackling it yourself you can try reseating all the connections to the drum motor and the DC controller board. Other possibilities could be a bad drum motor or a bad DC controller. HP says you can also get this message when the tranfer unit is missing or improperly installed.
If you don't feel like tackling it yourself then it's off to a repair shop unless it's under warranty, in that case call HP.
Jan 19, 2008 | HP Color LaserJet 3500 Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 3700n Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
