Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
I have ice but no water coming out from my door..?
  • 135 Answers
Check the inlet valve - most units have a dual valve and one side may not be working. Hope this helps!
Posted on Feb 16, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
Ice Cube maker in Frigidaire FRS23R4 refrigerator not wotking
The first thing to check is to see if there is any ice in the fill tube, where the water comes in, preventing any more water from coming in. If there is none then the water valve is bad, even though the water in the door works. Its a dual solenoid valve so if one goes bad they both have to be changed
Jun 05, 2012 | Frigidaire Refrigerators
Ice-maker does not work. water valve seems to be working.
There are 3 things that can prevent an ice maker from not working.
1- Temperature of freezzer- Temp must be below 6 degrees on most ice makers.
2- Water inlet valve- Depending on how your ice maker cycles it calls for water for 7.2 seconds. If you have ice and water though the door you have a dual valve and the ice maker selinoid ine the inlet may be bad. Also make sure water is getting to valve. Just because water is coming through the door does not mean water is entering fridge. There is a reservoir in fringe that holds around 3 gallons of water that can still make water come out the door without water entering fridge.
3- Faulty Ice maker- over time the winding and other components can get worn out and fail.
First check the temperature in the freezer.
Next check the inlet valve. To do this you need to remove the hose going from the inlet valve to ice maker and switch with the hose leading to door. Push the actuator in the door to call for water and see if water enters the ice maker. If it does inlet is good. Replace Icemaker. If not replace inlet valve. There may be a problem with the icemaker still but wont know until inlet is fixed.
If you have anymore problems or you need further assistance please feel free to contact
Jul 19, 2011 | Kenmore Refrigerators
I have a model GD5PHA whirlpool refrigerator, no ice
the ice maker control the water timing.
if you have voltmeter you can check it on the water valve that go to the ice maker. but you can also disconnect the water from the valve and see if water are coming out.
99% its the ice maker that go bad.
Jan 19, 2010 | Refrigerators
It makes no ice cubes, but water still comes through door dispenser. Why? There appears to be no water getting to the ice making mechanism, however water is still coming out the door dispenser.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water,light, or ice on the door
The control panel is most likely at fault. They are all controlled by the panel. Very rare for all 3 devices to go faulty seperately
Aug 27, 2009 | Freezers
The Kenmore Ice maker makes no ice. This is a side by side unit. The freezer is very cold. The water solenoid is not faulty, but is not turning on so the problem must be in the electronic ice level...
Good chance the water line near the ice maker motor is frozen. Thaw out the freezer for about 6 hours - move your frozen stuff to the refrig - ot should be OK - then back again after thawing. This alnost always works.
Aug 10, 2009 | Refrigerators
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
