Question about Mitsubishi WS-55809 55" Rear Projection Television
Cobwebs behind the screen of a Mitisubishi WT-55809
How can I remove the screen to clean the TV? Also, is a HDMI conversion kit out there for the TV itself? I would like to get Blue-Ray and use it to the fullest extent.
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello morsec,
    You will need to remove the screws on the back of
    the top half of the TV set. This will allow you to remove the top rear
    half of the TV and give you access to the screen. Make sure you do not
    break the mirror that is attached to the rear of the TV set. Clean the
    screen with a damp non-abrasive cloth dry with a dry non-abrasive
    cloth. When finish replace the back of the TV and tighten the screws to
    hand tightness.
    I hope this helps,
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
    Genius:
  • 1,199 Answers
Wile your in there you might as well clean the mirror and the lenses *and you will see a big change in your picture!
Remove screws from upper back of tv to access this area ..be carefull with the back the mirror is connected to it!Please rate this answer
Thank You!
Posted on Jan 15, 2009
Cobwebs inside screen
you need to take the top back off the tv. and mind the glass at the top of the rear part top it is very fragile, most of the projection tv have a side cover on each side so you can clean the rear of the screen, as you not said what type screen you have i cannot tell you further.
Feb 25, 2014 | RCA Televison & Video
Can the front cover be removed for cleaning?
yes normally its just small clips that are resealable used to hold it on as for maintenance it requires exposing the light bulbs
hope this helps
Robb
Apr 23, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
