I have used my printer (Canon ImageClass MF4122 printer) for about 5 years. Recently, the printer gives a fuzzy images whenever I print things. I have cleaned the printer interior, changed the printer ink density settings to dark, and changed my ink cartridge, nothing seems to work, and the printout I get is still fuzzy. What else can I do? Buy another printer? Please help, thanks.
SOURCE: Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
SOURCE: My Canon IR c3200 started to print olors out of focus...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
SOURCE: Need printer driver for Canon D880 Image Class
Here you go. Just select your OS from the drop down.
Please rate this solution.
SOURCE: Canon i9900 printer will not print group 2 colors.
Set your printer at maximum quality and dpi
SOURCE: images or graphs print incompletly (missed parts found)
in properties select high resolution.
