Question about GE 28112 Trio Cordless Phone
Code cl my phone has no dial tone and is flashing code cl
CL is for CLOCK, you must reset the time and date.
Posted on Apr 13, 2008
    Novelist:
  • 201 Answers
Which phone is having problems? the base? one handset? All? CL... Check Line?
Posted on Jul 07, 2007
2 Suggested Answers
SOURCE: CL flashing on base unit
I reset the day and time and then reset the phones by putting them in the base unit
Posted on Jan 10, 2009
I have a Serene CL-60AP phone. It receives calls but I can't get it to dial out. I hear it dialing like an old rotary phone but then the dial tone comes back.
You need to change the dialing mode to tone rather than pulse.
If you would like to know how to do this refer to page 26 of the instruction manual
50. DIALING MODE SETTING (TONE OR PULSE)
page 15 on the pdf file below
http://hearinglosshelp.com/store/wp-content/uploads/sites/2/2015/02/CL60Ausermanual.pdf
Depends on what your telephone exchange accepts as a dialing signal. Strange thing is phone is factory set to tone but it seems to sound like your phone is on pulse.
Mar 11, 2017 | Lands Phones
Uniden phone light WON'T flash red light when I have pulsing dial tone VM messages.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Aug 15, 2016 | Uniden Lands Phones
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I unplugged vtech tel to move to another location-now i have CL flashing and none of the phones have dial tone-how do i fix-thank you very much for your help
The main unit with the answering machine needs to be plugged into and outlet and also plugged into a working phone jack. The other units just plug into an outlet and speak to the main unit wirelessly. Make sure the main unit is plugged into a phone jack.
Jan 17, 2011 | Vtech Digital Cordless Telephone VT-2568
Conference Calling
If you have a flash button, you would use that to place the first call on hold and dial or answer a second call. If this is a single line phone in your home, you would have to have "Three Way Calling" feature with your local phone company. If you do, you could ask them what the dialable feature code is. It's possible they allow you to use your flash button, get dial tone and dial another person, when they answer, flash again to conference. If you don't have a flash button, they you would be using your Green or Off Hook button that you use to get your dial tone.
Apr 03, 2009 | Panasonic Lands Phones
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
Jan 09, 2009 | Uniden Cordless Phone
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Diigital answering machine and 3 portable phones
Here is the link for the manual; http://www.vtechphones.com/docMgt/public/art/20411/ip5850-man.pdf Page 23 - flashing CL means you need to set the clock. All explained there I think Hope this helps :)
Mar 05, 2007 | Vtech IP5850 Answering Machine
GE 28112 Trio Cordless Phone Logo
221 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
