Question about Panasonic KX-TG5632 Phone
Top row of buttons don't work
Have a KXTG 2432 and today the "speakerphone" "Mute" and 1,2,3, buttons don't work. I have it fully charged, have tried everything I can think of. The second phone works fine. I can use the faulty one to answer calls.
Well, I found the solution. I traded batteries from one the working handset to the non-working one, and the problem was corrected. Thus I need a new battery.
Posted on Jan 16, 2009
How do I put it on speakerphone?
Cricket Samsung Galaxy Grand Prime: Speakerphone:
1. During a call, tap Speaker to turn speaker ON
2. Tap Speaker again to turn speaker OFF
3. Tap Mute to mute the call
4. Tap Mute to unmute the call
see interactive map here that indicates where the Speaker icon is during the call
Using the Speakerphone
Jan 12, 2016 | Samsung Cell Phones
Mitel 5224 Speakerphone not working
it is likely the phone is in headset mode. If you've got a headset button programmed, then it should be lit.... if so, press it and it should work for you.
If you don't, you might be able to use the blue superkey to either turn off headset mode or set a button.
Press the Blue superkey, Press an unused button in the two rows of buttons. Press the "Change Key" softkey (under the display). Press No until you see headset key... press Yes.
Press the superkey again to get out of the programming.
Now that you've got the key programmed for headset, press it, if it's lit, press it again. Test your speakerphone.
If this doesn't work, I believe you would have a defective phone and should report it to your system admin or telephone system vendor for repair/replace.
Sincerely,
Mark
May 31, 2011 | Mitel 5224 IP Phone
My Apex tv at2402 is locked and i don't have remote control, what need to be done to get this fixed?
OK . . .
First, press the TV button at the top of the remote so the remote is operating the TV rather than the cable box. Then try these combinations - hold down both keys at the same time for 1-2 seconds before trying the next one.
ENTER and TV (on the top row)
ENTER and MENU
MENU and TV (on the top row)
If these don't work, try holding down the MUTE key and then press other buttons on the remote one at a time while still holding down MUTE. Do not use the number keys (0-9), the POWER key or any of the keys on the top row (DVD, AUX, etc) except for the TV key.
If this doesn't work, please post back with the model number of your AT and T remote and I should have some other suggestions. If it's not printed anywhere on the remote, the model number should be inside the battery compartment. If you remove the batteries, replace them quickly or you may lose any codes you have programmed into the remote.
I'll wait to hear back from you.
Anyone looking for assistance with unlocking this TV, with the original Apex remote, please click on this link for instructions:
http://www.fixya.com/support/t8361476-locked
Mar 02, 2011 | Apex Digital AT2402 24" TV
Model kxtg2432 display disappeared on hand sets started with one becoming intermittant then it stopped working all togeher now the 2nd handset is doing the same thing
I fixed my Panasonic KXTG 2432 phones by throwing them against the wall and buying another phone set made by another company . I also fixed a set of A.T.T. cordless phones the same way. seems to be the quickest way to feeling better about the garbage electronics being inported into the U.S. what ever happend to pride in workmanship
Dec 14, 2009 | Panasonic KX-TG1100 Cordless Phone
How do I mute my MLS-34D when using Speakerphone?
5104,
The button that mutes the speakerphone is the mic/HFAI key located above your speaker button. The mic mute feature works while using the speaker, when the phone is idle it works as the handsfree answerback intercom.
hope that helps,
Feb 09, 2009 | Lucent Lands Phones
My phone when I charge it is saying it's fully charged but it can't be beacuse I have not used it for months. When it comes on, it asks for the pin number but only lets me enter the second row of...
dear,
did u tried or open the internal cassing . i think any button is permantly pressed or causing this problem. u have to open the cover again of if first time then clean its keypad and then intially charge the full battery and then check.
try to do a master reset/default factory at the end, if issue is still persisting. But save contacts and sms first.  reset can delete them
regards,
Nov 28, 2008 | Sony Ericsson K510i Cellular Phone
Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
Jul 15, 2008 | Panasonic KX-T7731 Corded Phone
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Baby drool on my Treo 650
turn it off, try drying it with a hair dryer with the battery out then turn it back on, if problem still exist contact manufacturer for replacement
Nov 19, 2007 | Computers & Internet
Panasonic KX-TG5632 Phone Logo
81 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
