Question about HP LaserJet 2100m Printer
Laser Printer Ghosting - Still After Cleaning
Recently I am seeing echos or ghosting on my printouts from my B & W HP2100M LaserJet printer. I have just completed the built in engine and cartridge cleaning process, which didn't help. Any ideas? Tnx. DWS
  • dschutt Jan 15, 2009
    Replacing the toner cartridge solved the problem. I did not want to do that as I felt that the cartridge in use had toner left for many more copies. Oh well... Many thanks! DWS
  • 72 Answers
Try a new toner cartridge if that dontwork it could be your fuser.
Posted on Jan 15, 2009
Laser jet 4 plus.Starting to print with gosting or shadowing. Is it the end ?
We have several customers that still use the Laserjet 4+ printers and we keep them going. The ghosting you are getting is either caused by a bad toner cartridge or a fuser that needs to be replaced. If you have a spare toner try it first. The fuser assembly is inside the fold down door in the back of the printer. This assembly is what fuses(melts) the toner onto the paper. There is a heat roller that has a Teflon coating that wears off and can cause the ghosting too. You can get fusers from Ebay for $25-40 plus shipping. The fuser part number is RG5-0879 for the Laserjet 4+
I hope this helps, if so please rate our solution.
BuddyMc
Mar 08, 2011 | HP LaserJet 4 plus Printer
Blue, red and green are very average quality but yellow is not visible. On a windows xp test page. the yellow is replaced with an orange color. A logo test page indicates some ghosting/shading - for...
Ghosting and shading on this series printers is usually caused by either a bad fuser or out of date firmware. There were fixes in firmware that stopped ghosting from happening. As for the cleaning the lens. These models have a bad habit of collecting dust on the inside of the scanner unit and the only way to resolve that is disasemble the laser unit and clean the inside of the lenses.
Mar 04, 2011 | HP Color LaserJet 2600n Printer
HP 2600n is printing ghost which distorts text and objects
Using the left and right arrow buttons on the printer select the main menu 'service' press the green tick button in the middle of the arrows and now you are in the service menu press the right arrow once and you should see 'cleaning mode', press the green tick once and your printer should clean itself. If you are still getting ghosting you might need a new toner or maybe a service.
May 06, 2010 | HP Color LaserJet 2600n Printer
Oki C5500 printer has ghosting on most of the prints. After making a number of copies, the ghosting is greatly diminished and the copies are OK but not great. Started a couple of weeks ago. I have refilled...
This type of print problem associated with laser printers is due to the corono wire needing to be changed. The wire is not fully pulling the toner off of the drum completely. If you can access it, cleaning it may help (usually a lever that you are supposed to run back and forth a few times that wipes the corona wire). If the cleaning doesn't help, then it probably needs replacing.
Feb 08, 2010 | OKI C5500n Printer
Ghosting
its probobly drum then you need to replece it
Dec 23, 2009 | Dell 5110cn Laser Printer
HP laserjet 2100 prints pages fine, but has "ghosting" and duplicating text and images several lines down from original text/image. Recently installed new HP toner cartridge and was working fine for about...
Sounds like a bad drum on the cartridge. Contact HP, and they will probably replace it free, or maybe help you to troubleshoot.
1-800 HP-INVENT
Hope this helps!!
Sep 05, 2009 | Sharp AL-1000 Copier
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Printer is ghosting - I have changed power supply
Might be your transfer roller. I would try some laser cleaning paper and run that through a few times. If that doesn't work, I would purchase a fuser maintenance kit which will have the rollers as well as a new fuser.
Dec 15, 2008 | Brother HL-2040 Laser Printer
Printouts have type ghosting
Change the fuser unit if you have to hand. The problem is likely caused by a lack of pressure from the pressure roller. Also check the transfer roller for a similar ghost image.
Sep 14, 2008 | Samsung CLP-510 Laser Printer
Xerox DocuPrint P8 Laser Fuzzy Printing
Maybe a bad fuser . That would cause ghosting and reprint on the page
Feb 02, 2008 | Xerox DocuPrint P8 Laser Printer
HP LaserJet 2100m Printer Logo
158 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
