Question about Sony DVP-NC600 Multi-disc DVD Player
Sony 5 disc dvd player - discs lock in - spinner needs push to go
Our 5 disc dvd player has not been working for a while - I took the cover off to see if my son had perhaps put an extra disc in there and just noticed that the spinner was not spinning the discs. They lock in properly and once I gave the spinner a little push it took off and all 5 discs played on our TV. I put the box back on and am now having the same problem....is there some product to spray on the spinner to loosen it - like a wd 40? I don't want to ruin it but also don't want to pay for service since I know what the problem is!
  • 10,594 Answers
You can spray WD-40 contact cleaner but very little amount in spindle motor (you call it spinner) and please take care, DO NOT spray over optical lens which is so close to spindle motor.
If problem still exist, you need to replace optical lens assembly and I will provide you part number if required.
Good Luck.
Posted on Jan 15, 2009
Hello. I am having a similar problem, My DVP-NC600 wont even pick up the disc. It was working fine, then one day it didnt. First off, after inserting disc in carasuol, I press the close button and it starts closing as normal. Then when it gets about an inch or two from fully closed, it stalls and slows then closes. After it finally closes, It will not pick up the disc at all. Then 5 seconds into it, the carasuol opens back up with a little stall at first in the same spot when it closes. Please help, I really love this unit and am not looking forward to replacing it... Thanks, Rob.
Posted on Jul 10, 2010
Why does my sony DVP display "No Disc" for every disc; when they play fine in any other player?
Sony tend to have a notorious disc lasers... couple of things you might want to try..
1. clean the lens using a standard Lens cleaning CD.
2. Try playing a CD (music) instead of DVD (if this works...it is likely that the lens is not reading DVD)
N
Jun 02, 2014 | Sony Dvp-C660 Component Dvd Players
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
Feb 29, 2012 | Sony DVP-SR200P DVD Player
Child tilted 5 disc dvd player with discs in the
unplug the dvd player, now take the screws off the cover there may be 4 to 6 screws around it , from the back of player use both hands and lift the cover off gently .. you will gain access to the dvds DONOT SHAKE THEM OUT!!!!!! take them out gently one at a time... this should solve your problem..
Let me know if this worked
Good Luck...
Dec 23, 2009 | Yamaha DVD-C750 Multi-disc DVD Player
Disc stuck in machine. took off cover. can see
Find the electrical motor and try to turn it with your fingers, it should move the gears in order to release mechanism. It its stops and no movement, turn the motor the other way.
Sep 12, 2009 | Sony Televison & Video
DVD Scratches
i think its the player, the distance of the spindle motor spinner is quite near the pick-up assembly that is why slight vibrations affects the unit.
Aug 20, 2009 | Sony SLV-D380P DVD Player/VCR
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Locked??
I had this problem, it was a jammed disc. I disconnected the dvd player and removed the cover. Then I checked out the trays and sure enough a disc was jammed. It took a bit of very gentle work to free the disc as the jammed tray needed to be unlocked so the tray self slid and released the offending disc. Once that was done I placed the cover back on and reconnected the wiring...and all was well.
Jun 02, 2008 | JVC TH-M606 System
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player Logo
311 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
