Question about Epson Stylus CX4800 All-In-One InkJet Printer
Everytime scanner option is selected an error message pops up
Every time i select scanner option an error message pops up and say`s escndv.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
  • Anonymous Mar 11, 2009
    I had the exact same problem as described above. The odd thing is that on the same computer, other users could scan under their own login without problems.
    This solution worked great.
    Thanks Bunnydawg
  • originalrays Apr 27, 2009
    un-freaking believable. Solution #1 from stixlix worked! I am running XP SP3 with a Epson Perfection 4180 scanner and I had the same problem with the scanner software not working. I have been running this scanner with XP for years without incident. The last time this happened, I gave up and reinstalled Windows because I could not figure out what was going on.
    When the same problem happened tonight ("escndv.exe has encountered a problem") I was filled with rage and anger. I had completed one scan, and then all of a sudden Epson Scan decided to stop working!
    I tried uninstalling the USB devices. I tried restoring a previous checkpoint. I reinstalled all the software (from the original CD, and then the 2.65A driver update for XP). I even went into the registry and started deleting entries for multiple Epson scanners (don't do that at home, kids).
    Of all things, I went and deleted the scan file as instructed, and miraculously, Epson Scan began working again!
    This should be the top search result on Google.
    Note: I was actually looking for something like solution 2 (wipe out all traces of the scanner from the system and reinstall fresh) but amazingly, deleting the bitmap file did the trick.
I Had the same issue, worked on it for weeks, was told it was registry issue, I reinstalled the software, said it was hardware problem....THEN I FOUND THIS AND as simple as it seems, IT WORKED.
Please follow the instructions below to help resolve this.
  1. Go to My Computer, by right-clicking the Start button. Select Explore
  2. Double-click the C: drive, then navigate to the following folders or location on the hard drive: C:\Documents and Settings\%username%\Application Data\EPSON\ESCNDV\ES00XX (where XX is any numbers or letters)
  3. Look for a BMP file or any file in this location and delete this file OR FILES THAT ARE .BMP.
  4. , can be xxxxx.BMP ( where xxxxx is the name)
Note::
  1. %username% above stands for your PC username.
  2. The Application Data folder is hidden by default, to un-hide this folder do the following in your Windows Explorer window go to the Tools pull down menu and select Folder Options
    Click on the View tab, look for Hidden files and folders.
    Select Show hidden files and folders option
    Click OK.
    you should now be able to see the Application Data folder continue in to the folder path above.
    (You may have to follow the steps again to turn off the Show hidden files and folders feature. )
  3. Removal and reinstallation of Epson SCAN does not clear out this file.
Posted on Mar 23, 2009
    Brigadier General:
  • 5,158 Answers
Very verbose answer but this is supposed to work
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or
OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on
CHANGE/REMOVE.
7) Go to START, SEARCH, and ALL FILES AND FOLDERS. Select Advanced option
and ensure there is a checkmark next to SEARCH HIDDEN FILES and FOLDERS.
8)Search for files where all or part of the file named is OEM*.* and a word
or phrase in the file contains EPSON. Search location should be set to
C:\WINDOWS\INF or C:\WINNT\INF.
9) Delete all files that are found if this is your only Epson product. If
you have another Epson product, you will want to open each individual file
and determine which files pertain to your scanner, and then delete only
those.
10)Go to START, SEARCH, and ALL FILES AND FOLDERS. Search for files where
all or part of the file named twain.log . Search location should be set to
C:\. Please delete the twain.log file and repeat the process for
twain001.mtx, twunk001.mtx and twunk002.mtx. and epfb5 and escndv
Now we need to remove specific references to the product in the registry:
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the "+" sign next to
HKEY_CURRENT_USER
9. Click on the "+" sign next to SOFTWARE
10. Click on the "+" sign next to Epson
11. Look for a folder name EPSON SCAN or epson twain . Right click on it
and Delete it (if you don't see it, then don't worry about it).
12. If you see a reference to your Epson product model, right click and
delete it.
13. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_CURRENT_USER to
close up this branch.
14. Click on the "+" sign next to HKEY_LOCAL_MACHINE
15. Click on the "+" sign next to SOFTWARE
16. Click on the "+" sign next to Epson
17. Look for a folder name EPSON SCAN or epson twain , Right click on it
18. If you see a reference to your Epson product model, right click and
delete it.
19. Click on the "-" signs next to EPSON, SOFTWARE, HKEY_LOCAL_MACHINE to
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your
scanner model.
3. Under the Drivers & Downloads section select Windows. Download the most
current version of the Scanner Driver for your Windows operating system to
your DESKTOP.
Reinstall
1) Double Click on the Epson1****.exe file that you downloaded to your
DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when
prompted.
4) Connect the USB cable to a different usb port on the computer. Windows
will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO
TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
Posted on Jan 15, 2009
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Using XP Pro, with correct driver. Error is "Unable to Select Twain Source. Edited Path to include: %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem; C:\WINDOWS\twain...
You will need to install the twain driver for the scanner.
Click on the link below and download the driver. Once its downloaded execute the .exe file. you will then get a small box pop up with "Unzip" on the right hand side. Look at the path of the unzipped file on the left hand side and save it to your desktop. For example C:\users\yourname\desktop instead of C:\Users\yourname\AppData\Local\Temp. The file extracts quite fast so go to the desktop and run the SETUPSG.EXE file. When its installed you should be able to use the scanner.
Download Canon Scan gear here >>>>>>>
http://modrv.com/scanners/canon/402prog.html
Good luck and kind regards.
Dec 14, 2010 | Canon CanoScan N670U Flatbed Scanner
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Escndv.exe problem connected with Epson scanner 4490 Photo
http://www.howtomendit.com/answers.php?id=64090
Go here: C:\Document
s and Settings\[username]\Application Data\EPSON\ESCNDV\ES0058
and delete any image files in that folder. The last folder might have a different number depending on your scanner. It should start working again.
If you can't see that folder - click on My Computer - in the menu click on Tools and select 'Folder options..." Click on tab 'View' and select 'Show hidden files and folders'
You should now be able to see 'Application Data' in Docs and Settings...
May 30, 2009 | Epson Perfection 4490 Photo Scanner...
I cannot open my scanner instead this appears:"escndv.exe has enc
try downloading and installing the copy utility v3.3. usually nost espon hardware need more than one driver to work properly. my printer needed 3 drivers...
Apr 16, 2009 | Epson Perfection 3590 Photo Flatbed...
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
My scanner
scanner error see ur documentation and callservice if necessery
Oct 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner will not work!
One more try - this way
Remove all previous installations using the the Epson uninstall feature9Go to start/Programs/Epson side menu - uninstall.
Do this to all Epson modules.
No go to Start/Run in the filed type -REGEDIT
IN Edit[on the top bar] cclick on 'find.' in the field type EPSON
delete all that comes up.
Restart the machine.
Make sure you are offline.
Disable the Antivirus software.
Making sure the Software CD it spotless clean put in the drawer and follow the prompts.
Come back with with results - goood or bad
Nov 26, 2007 | Epson RX620 All-In-One InkJet Photo...
Error Code 009 Scanner out of paper
Right-click the VRS icon in the system tray. Select QC Modes and uncheck Hardware Errors. This will stop VRS from flashing the out of paper message.
(Also, ImageNow has it's own prompt when the scanner is empty. You can turn that off in the Scanning Profile on the Properties page.)
Oct 16, 2007 | Canon DR-9080C Path-Through Scanner
Epson Stylus CX4800 All-In-One InkJet Printer Logo
998 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
