Question about Nintendo New Super Mario Bros. for DS
On the last castel
When u keep going around in circles the paturn is down high middle
  • Jennifer D
    Jennifer D Jan 29, 2009
    I am stuck in the same spot I think! Arg! I am at the last castle (Bowser looking type castle) and I am exactly half way thru...and I went thru a door that took me to a screen that just repeats itself over and over but I don't get any progress when I look down at how far in the level I have gotten...HELP!!! Where I am stuck it is just lava, blocks, and bricks...does anyone know where I am talking about?!?!?!
  • 71 Answers
Firlst go down, then go up, then go middle.
got it?
Posted on Sep 04, 2009
  • 7 Answers
I found the solution and won the game! Watch the walkthrough and do EXACTLY as this player does...
http://www.youtube.com/watch?v=b39vSV0HFI4
Posted on Jan 29, 2009
I have a HP tablet that turns on but has a big circle in the middle going around and says cyanogenmod
Your tablet's firmware has been modified with aftermarket software. (users typically do this to gain "root" access on the tablet.) If the software will not load, you will need to either load the factory firmware, or try another aftermarket firmware.
Oct 23, 2015 | HP Tablets & eReaders
I've forgot my code for samsanite case and its locked please help
Set the lock on 999, push the buttons on the latches to the outside. If that doesn't work, roll the last number from 9 to 8 and try again. Then roll it to 7 and keep trying, rolling the last number down to 0. Then roll the middle number from 9 to 8, and move the LAST number to 9, and start the whole thing again. When you get to the end of that, roll the middle number on down to 7 and the LAST number on down to 9. Keep doing this until it unlocks (note the numbers at that point to remember!), or, you may have to go on down through the first numbers as well. You only have 1000 possible combinations. That sounds like a lot but if you are watching TV while you are mindlessly rolling a number wheel and then pushing the latches out, it's not too bad, only about an hour ... your thumbs will get sore. :-(
May 31, 2012 | Photography
My gas pool heater is banging
Hayward, gas heater... a metal clinking noise and the hoses doing a twitch every 5 to 20 seconds. my experience says it is that diverter shield has come loose...disconnect everything. unscrew the in and outlet connections.look into the hole, you will likely see a metal, plate with two half circles, one facing the inlet hole, and if you go around to the other side you will see the other end of the plate, with a half circle. this plate comes loose, whatever they use doesn't last.
one guy used a small hose clamp to keep it from sliding up and down the post, I used that two part plumbers putty, to "weld" it in place....homedepot, comes in a small cylinder, it's two part, you cut off a piece and mold it in your hands, worktime is only 3 min. cures in an hour.... no more clinking metal or twitching hoses.
Apr 27, 2010 | Hayward H Series Induced Draft Abg 100,000...
Operating instructions for a Transtherm Castel
Go to the transtherm web site(type "transtherm" into google etc) click on the "Technology" tab at the  bottom of the page and download the pdf file at the  top of the resulting page.
Mar 02, 2009 | Transtherm Castel
I have the Roomba Scheduler. It just keeps going
its going in circles because it thinks it bumbing something try using commpressed air and blow out the the bumber sensors
Mar 01, 2009 | iRobot Roomba Scheduler 4230 Bagless...
1991 CR 500 (reving to high on idle high serges)
take some wd 40 & spray around the carb boot while running to see if the idle drops for a few seconds. sounds like you have an intake side air leak causing a lean condition making the motor rev high.
Feb 16, 2009 | 2001 Honda CR 500 R
Warning lights on land rover dicovery 1993
A circle with lines around it - depends where it is -
If its a top left light, then it should be a circle with an exclamation mark in the middle, and two lines running part way round the outside (1 to 5pm and 7 - 11pm). Thats the handbrake and brake fluid light which comes on for about 3 seconds when you start the engine ... if it comes on at any other time - seek help.
If its top centre, and has ABS in the middle, then its the anti lock braking light. Similar to above, lights up for a few seconds at start.
Muffler with lines coming off it - are they pointing outwards from the circle, (with a thermometer in the middle = transmission oil temperature guage), or are they on the left and all parallel (which would be main beam indicator, which lights up blue when on)
Feb 15, 2009 | 1995 Land Rover Discovery
Leaves about a 1/4 inch space down middle of paper.
That is the cleaning assembly in the drum cartridge.Either something slipped into the cartridge or the blade tucked. Sounds more like something is in the cartridge blocking the drum from both cleaning and charging/
Mar 05, 2008 | Sharp AL 1631 Copier
Nintendo New Super Mario Bros. for DS Logo
63 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
