The ice maker is working but the dispenser has stopped dispensing ice. It seems the auger is not working. After removing the ice bucket, I have shut off the light and then attempted to activate the auger but it does not turn. I have taken the ice bucket out and verifed that it was clean and not frozen up.
It can be faulty ice maker assembly and needs to be replaced. Replacement parts can be
purchased at any of the following web sites: partsselect.com -------------------- Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: ice maker drive mechanism won't turn
Remove ice bucket and rinse throughly. Hold down door switch an press for ice you should see the drive in the back for the auger turninig if not youll need to find out uif auger motor is getting electricity and/or is operable.
The ice
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
This will help. Thanks. Helpmech.
