Power cord for Viewsonic VE700 Model # VLCDS23724-1W
We have a working monitor, but when we moved it, we misplaced the cord, if we knew what it looked like, we could find it. Thanks CB
    Genius:
  • 2,120 Answers
Try eBay.
Posted on Jan 16, 2009
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
http://www.viewsonic.com/us/support/downloads/search_user_guides/
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
The monitor won't work with my computer. It says the input to the display is analog. I need a VGA adapter. What do you think. It's a ViewSonic VE700 monitor.
first I would double check in your big box of computer junk look for one of these. that is if your computer has dvi output. Then you should be able to connect to your VE700 with a standard VGA cable, with the Blue ends.8ff5302.jpg
Sep 01, 2010 | ViewSonic VE700 17" LCD Monitor
Where can I get a power cord for the ViewSonic VE700 LCD Monitor
Hello there:
Most of the computer stores or a electronics store like office depot or radio shack or walmart or k-mart ect ect ....will have these cords
Furthermore if you have a second hand store in your area they might have them there too
Hope this is very helpful for you>
Best regards Michael
Jan 05, 2010 | ViewSonic VE700 17" LCD Monitor
When the computer is turn on, the image in the monitor appear and disappear rapidly
More likely to be bad caps in the power supply, that is the first place to check, worst can be bad lamps also.
Jan 04, 2010 | ViewSonic VE700 17" LCD Monitor
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
My viewsonic monitor works fine for some time but the n suddenly stops displaying even though the power cord is fine ...after some time it comes alive or some times by fidgeting with the power cord.....
It sounds like a loose connection. The easy thing to try is to replace the power cord to make sure that's not the problem. If that doesn't fix it, it's probably a broken or loose wire inside the monitor that you would need to trace down with a multimeter.
Oct 16, 2009 | ViewSonic VX924 19" LCD Monitor
Comes on and back off got picture
This monitor is start to have intermittent operation due to component failure. This may be from overheating or aging. The unit should be taken to a service center that has service information for this model monitor and thoroughly tested for possible component damage.This should be done before the situation get worse and causes a major failure of the boards. I hope this information helps you with your problem.
May 24, 2009 | ViewSonic VE700 17" LCD Monitor
LCD monitor problems.
Hi.
If the monitors use seperate plug in power supply EG 12 to 24volts it could be that at fault.
Or it could be the invertor at fault.
I have had some success repairing invertors if you can use A meter remove invertor Panels & check accross the coils with meter set to ohms all the coils should read identical chances are you will find one set of windings either dead short or open circuit. This will be the faulty coil hopefully as your monitors are all the same make the coils will be the same.
Carefully desolder faulty coil & fit one that reads good from a doner board.
Look for any SMD type fuses & check or replace them & thats it I have done quite a few now using this method.
Give it a go.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
727 people viewed this question
David Payne
David Payne
