Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Hi am having truble whith turning on my monitor its telling me monitor going to sleep
  • Dan rogers
    Dan rogers May 11, 2010
    check the plug on the monitor and check the other side where you plug the monitor into the computer. It sounds like your monitor cannot detect any signal. If the plug is ok then try to hook up a different monitor.
    Do you have a video card in the computer or is it built in the motherboard?
    If you have a video card and there is no display on another monitor you will have to look into getting a video card for the computer. It is not that un-common for video adaptors to go out but that is when it is nice to have a desktop computer. You can normally just put another one in.
    Should have asked this first but what provoked this probelem?
  • Michael Lucas
    Michael Lucas May 11, 2010
    Sounds like your monitor is power save mode. What type monitor is it. Type and model #
    Problem Solver:
  • 9 Answers
Check and make sure your Video Card is attached well.
Posted on Apr 21, 2009
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
After going off line then want to go back in 1 hour, it tells that monitor is going to sleep, how can I prevent this
To prevent your monitor from going to sleep you will need to...
Go into your Contol Power Options or Battery Settings....Click on Battery Power Saving Options....selcet...Never...under put to sleep.
You will have to start Logging Off at the Start Button.
Kind Regards!
Sep 23, 2011 | HP Pavilion F1703 17" LCD Monitor
Hp l2208w going sleep
I am sorry that the Monitor is going to sleep mode. Are you experiencing the same issue with different Tower or CPU? Turn OFF the monitor and power cycle it after a minute and check if the same issue persists. Also, reinstall the Video Driver.
Jul 16, 2010 | HP L2208W Monitor
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
May 16, 2010 | HP Q1859 18 inch Monitor
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
Works when it wants to then turns whie with grey line in it
If only the monitor is going to sleep, then it could be a problem with the connection from the monitor to the computer or with the cable.
If the computer goes to sleep and if you are not able to wake it from sleep then check the sleep mode settings and also the power management settings for the keyboard and mouse.
You may also do a system restore if you are not able to wake the computer from sleep.
Feb 24, 2008 | Sony SDM-HS73P 17" LCD Monitor
Going to sleep
(if you have an orange light) Turn off your computer and unplug all of your devices, printer, scanner etc... Only your monitor, mouse, keybord and monitor should be connected. Now turn on your computer. It should work now. You can attach your other devices if you are successful.
Nov 15, 2007 | HP Pavilion F1523 15" LCD Monitor
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
