Question about Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher
Dishwasher filling correctly?
We just bought a whirlpool gu2700 dishwasher and installed it ourselves. it ran very long cycles and we realized the dishes were not coming clean. we found that a valve in our kitchens plumbing was restricting the water flow to the dishwasher. that is fixed and we have great water pressure to the machine now. but i do not know if the machine is filling properly. the water entering the machines tub is at a much lower pressure and only fills recessed hole in the center of the machines floor (where the sensors and drain are) and does not fill the entire floor of the tub. Is the water supposed to fill the floor of the tub when the cycle starts?
  • Anonymous Aug 24, 2008
    when you start the dishwasher water does not want to come in
Dissassemble the fill valve and verify that the plastic screen is clean. If so, look undr the screen and remove the black rubber washer (but leave the white plastic restrictor in place).
Posted on Mar 10, 2008
    President:
  • 878 Answers
John, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
Posted on Jun 17, 2007
Correct cycle. Get to wash dishes.
Whirlpool Dishwasher Repair Online Manual
www.appliancerepair.net/whirlpool-dishwasher-repair.htmlFREE ONLINE Whirlpool dishwasher repair manual - Diagnose your problem ... Noneed to call an expensive serviceman, and then wait a couple of hours (or ... Common complaints are covered, such as wash quality problems (spotting,
Jul 19, 2015 | Whirlpool Dishwashers
Whirlpool gu2700 dishwasher
Water is not heating. Could be bad heater, bad control board, or poor water circulation due to clogged, stuck, or bad pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Jul 27, 2014 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Dishwasher doesn't fill with water!
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 28, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
Whirlpool dishwasher DU810CW fills for 20 sec.
well the timer and the float are the only two things that control your fill cycle,
so since your float is correct ie the rinse cycle
we can only assume that it would not be intermiten it is just a cherry switch
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=255697&diagram_id=77498#d77498
here is the link to the part (timer)
and the breakdown of how to get at it
Oct 27, 2009 | Dishwashers
Won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Mar 21, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Detergent (gel) always left in dispenser and on bottom of door
Get package of unsweetened limonade drink mix and put in machine and run a cycle, this will clean all parts of hard water deposits. Cascade powder is the manufactors choice, till they get ad space and samle giveaways
Mar 12, 2009 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
The dishwasher fills with water and doesn't shut off at the start of the wash cycle.
I have a hotpoint dishwasher. I ran the dishwasher and it went through all the cycles but on the last drain cycle it didn't drain? Any suggestions
Oct 29, 2008 | Whirlpool Dishwashers
Open Questions:
See all Whirlpool GU2700XTSS / GU2700XTSY Built-in Questions
Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher Logo
370 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
