Question about GE Washing Machines
Model blown on washer
Model #wjre5550h1ww purchased 12/2/07 motor burned out dec 21,2008 is this stilled covered and how lon?
  • 66 Answers
1 year parts and labor.But some is up to 10 years. Here is a link to look at you warranty.Here is G.E phone number.1-800-432-2737 http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90351.pdf
Posted on Jan 16, 2009
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
Feb 27, 2012 | GE WBSR3140DW Top Load Washer
I have a 2yr old WJRE5550H1WW that all of the sudden will not spin - it does everything else correctly just no spin action? Any ideas?
A lot of times different problems with that type of GE Hydrowave washer can be resolved by resetting the control board on the motor. Its very simple to reset the motor board and see if that solves your trouble. This tip i wrote explains how to reset that motor control board. http://www.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Sep 12, 2011 | GE Kitchen Ranges
My ge wjre5550h1ww wont spin. everything else work up to that point
Might need to be reset. To Reset the Inverter board on the motor push the timer knob in so the washer is idle or if digital have the machine in the off position. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. This might take more than one time. Service Manual and MORE HERE
Aug 23, 2011 | GE WBSR3140DW Top Load Washer
I have a cabrio purchased in dec of 2007.. model
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
LR CODE ON A NEPTUNE 55OOBWW WASHER
Hello there:
The LR error on your non-spinning Maytag Neptune is usually, thoughnot always, accompanied either by a burn spot or a blown fuse on theMotor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge)Either way, it means just one thing: a new motor and motor control board kit are in your future.
Hop this is very helpful for you
Best regards Michael
Dec 29, 2009 | Maytag Washing Machines
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do you open GE washer model WJRE5550H1WW? When my washer adds water, some of the water drips down towards the bottom of the machine.
on the front panel under the lid/top piece are two clips use a screw driver to push trawards machine and it will bring front panel towards you and unhinge piece wala! all exposed
Oct 01, 2009 | GE Washing Machines
Burning rubber smell followed by a hum and the washer stopped
Hi, there was some sort of gear trauma inside the gear case that locked up all rotation during full motion. I'm sure this destroyed the motor and all the windings inside the motor. the clutch was damaged as well. you may have to replace the entire drive assembly and motor. if you have a warranty, im sure this will be covered if the warrenty is still good.
Mar 14, 2009 | Washing Machines
Monitor goes black, with ghost lines of white. unplug and replug sometimes works sometimes does'nt. it's almost like it's burn out, or blown. pounding on the top works great, it comes right back on. this...
Its more or less your monitor has gone bad.
To check the same , unplug the monitor from the computer , a slef test feature check would be displayed . Check if the monitor goes blank or shows ghost lines . If yes the monitor is bad. If you have got the system before 12 Dec 2005 its generaly covered under 3 yrs warranty.If purchased after that , it would have your system warranty
Apr 20, 2008 | Dell Dimension 3000 PC Desktop
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
179 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
