Question about SuperMicro P4DC6 with FERRET RESISTORS (MBD-P4DC6+PL-P) Motherboard
2.2 ohm 2 watt resistor
How can i make one 2.2 ohm , 2 watt resistor by puting two smaller ones together, if that can be done, I am trying to fix a tv set that calls for the 2.2, but RadioShack doesnt seel that size, but they do sell smaller sizes
  • okidih Jan 25, 2009
    hello, I have been trying to fix a resistor of the same value in to my machine but it just burns as soon as I do it,,,, what could be the problem please?
    Sergeant:
  • 270 Answers
Connect two 1.1ohm,1watt resistors in series.
Posted on Jan 16, 2009
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
What does code n153 mean ]
In the future please be more specific about what you drive. So now I'm going to have to guess what you drive.
OK, 2001 Jetta, three-wire airbag plugs, two wire seatbelt plug (passenger side), four wire seatbelt plug (driver's side). Put in different seats. This is to eliminate the airbag light and restore the order: 1. Connect only positives on airbag plugs with a 4.7Ohm, 1/2 watt, 5% tolerance resistors; 2. Passenger side seatbelt plug: connect with a 2.2K Ohm, 1/2 watt, 5% tolerance resistor; 3. Driver's side seatbelt plug: bundle two positives together (in my case, red and yellow), two negatives together (two browns). Then connect with a 470 Ohm, 1/2 watt, 5% tolerance resistor. 4. Use Vag-Com to clear codes.
Aug 20, 2013 | Volkswagen Phaeton Cars & Trucks
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
I have a jl 1000/1 mono amp and my low ohm light was on and making a buzzing sound and found that there was a resistor that one of the terminals broke off and now no matter where i look i cant find the...
The 5 ohm could be challenging, what you could try is to get 2 10ohm 3 watt and put them in parallel. Will be 5 ohm and 10ohm is easy to get
Hope that helps
Jul 26, 2009 | Car Audio & Video
L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hitachi
They have it, they just list it as a 1-4 watt resistor, just order two of the 1-4 watt resistors and they will send a order confirmation inquireing which rating you need for those two items within minutes of your order.
Jul 16, 2008 | Hitachi 57F500 57" Rear Projection...
Blue won't line up at the top in digital array
you need to replace both convergence ICs and the six 1 watt feed resistors. The ICs are both STK392-110 and the resistors you need one of each RK42 3.3 ohm 1watt, RK46 1.8 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt and RK62 2.2 ohm 1 watt.
You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Hitachi 43UWX10B 43" Rear Projection...
KP-57WS500
If you look at the Convergence ICs you will notice a row of resistors under the fins of the heat sink. Those are the 4.7 ohm resistors. Also in that same row of resistors you will notice the 6 yellow picos they are all lined up the picos have 4 grouped together then 1 more on each end of that row or resistors.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Resistors
Okay R939 resistors are 3.3 OHM 2 watt metal film. and R950 are 270 OHM 2 watt metal film. The 3.3 ohm are the most likely. One end has to be unsolderd fro circuit and lifted out to check them if they dont read 3.3 ohm they need to be replaced as they are 5% tolerant resistors. I Cant find the rating for R392 can you tell me the color bands on them and are they the same size as the other two type resistors? The 3.3 are the ones I would check if they read 3.3 they are good but if they dont measure or measure high replace them, and let me know the details on R392 color bands and size.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Computers & Internet Logo
336 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
