Question about Soleus MA-9000AH Air Conditioner
Does hose vent neeed to go out window to use heater option??
Do i need to put the hose out the window to use the heat option fast reply needed thanks
  • 24 Answers
Yes you do.
Posted on Apr 15, 2009
Heat/defroster doesn't work. blower does.
As far as heat, does the engine reach normal operating temp? Do the heater hoses get hot? Can you check circulation through the heater core?
Check the actuator doors under the dash, see if properly operating?
Oct 14, 2016 | 2000 Pontiac Grand Am GT
I recently purchased a Danby Premiere 13000 btu portable air conditioner. I live in a condo with swing out windows. What are my options for venting (short of returning the unit for a refund or replacing...
John, unfortunately, you don't have many options, short of putting a hole in an exterior wall and putting an exhaust pipe with a cap (like a dryer vent has) and connecting the exhaust hose to it. OR if you have a clothes dryer in your condo and it's vented to the outside. You could temporarily disconnect the dryer's vent hose and connect the A/C's vent hose to the the dryer's outside vent.
Either way, it may be to much of a hassle . But, I'll let you decide that. I guess it will all depend on how hot your condo gets without A/C.
Let me know how it works out for you. Thanks.
May 05, 2011 | Danby Heating & Cooling
No heat,engine temp.is normal
the valve that allows the hot water into the heater core is not opening. most likely electronic issue. also check all vacuum and electric lines.
Nov 03, 2009 | 2000 GMC New Sierra 1500
2007 Suburban LT .....I turn air/heat on all options but air will not come out front vents. It only comes out foot vents and/or defrost vents for driver./passenger front windows.
Need to look under hood for a vacume line going to your fire wall. your vents are vacuum assisted and i have had this hose dry rot from the engine heat causing my vents not to work correctly. the hose is normaly about a half inch in diameter and is towards the middle of the enigine compartment.
Oct 15, 2009 | Chevrolet Suburban 1500 Cars & Trucks
NEED A LITTLE MORE HELP 88 CADILLAC ELDORADO NO HEAT,HAVE REPLACED THE THERMOSTAT STILL NO HEAT.TALKED WITH DEALER THEY SAY NO HEATER HOSE CONTROL VALVE HOW HARD IS THE CORE TO GET AT. CANT SEE HOSES UNDER...
The heater core may be stopped up.Remove bothe heater hoses from the heater core,and use a water hose to flush out the heater core.Put the water hose up against one heater core pipe,it will come out the other pipe.Make sure the vent door inside the car is moving when you select heat,If I can help,any further,please let me know.>>roniecon@gmail.com
Oct 06, 2009 | 1988 Cadillac Eldorado
Steam coming out of vents and water runnind down inside of dash
Your heater core has corroded through. You need a new heater core. You may be able to get by temporarily, with bypassing the heater core hoses, located in the engine compartment. These hoses carry coolant heated from the engine, to the heater core. You remove the hoses from the core, and put a pipe in the middle, connecting the two hoses together using hose clamps.
Should there be a cool morning, or if you need the defroster, you won't have warm air. Just a temporary fix.
May 10, 2009 | Mitsubishi Cargo Cars & Trucks
'04 Jeep Grand Cherokee: Heats...but only through defrost vents.
Check the control cable that operates the diverter door in the heater box at both ends, to make sure that it operates the door when you move the control lever.
Jan 15, 2009 | 2000 Jeep Grand Cherokee
No heat! changed fluid, thermostat. Was going to check control valve but don't know where it is. if that is not the prob should I change the core
This problem is one i have encountered on a number of vehicle not just your brand. The problem seams to be in the controls switches and sending units. you have change lot of parts but did you check to see if you had flow through the heater core.Remove the heater hose's from the engine going to the fire wall. This is not precise in how you get the hoses off, however you do it? Once the hoes are off take a garden hose and try to run water throught the heater core. If you do not have a flow you need to find the closed valve. You may need to block off the hoses to the engine so you can run it for a vacume system. You may need to cut and put splices in the water hoses to do this. As a lot of engines you can not get to the end of the hoses.
This is not a simple fix as you would think. As i have found the heater hoses are getting warm or hot with the engine running but it is still cold inside the car. The word is no water flow no heat and if you have flow you have a vent door stuck closed. Air conditioner controls can have effect also. you may also may need to check the water pump out put to the heater core. This needs to be done with all the anitfreeze removed so as not to lose it on the ground. If you do remove the anitfreeze you can check the heater core flow by only removing 1 (one ) hose for the firewall to the heater. if you have hose off remember to put the garden hose in the radiator with it one as not to over heat the engine while it is running. you had heat before it a matter of tracking down where the flow has stop or the cause like a bad switch, broken wire or vacume hose.
good luck
Dec 31, 2008 | GMC Jimmy Cars & Trucks
Soleus MA-9000AH Air Conditioner Logo
156 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
