Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsu ws55511 Won't turn on
I've replaced convergence ic, 2 resistors, 2 pico fuses, and 7 capacitors. Green light blinks for a min or so then turns off. Press power (remote or tv doesn't matter) acts like its going to turn on then it doesn't. I'm at my wits end and need help.
  • 4 more comments
  • darthdave Jan 15, 2009
    Which junctions?
    The tv trys to turn on and doesn't, I'm getting a code 22
    Where is the power supply?
    Code 22 the remote is fine, the buttons on the front of the tv are fine, I just can't get the tv to turn on...
    I've got the schematics anyone have an idea where to start?
    Thanks for all the help!!!
  • Mitsubishi Master
  • 19,396 Answers
Well done.
Thanks for using Fixya.
Posted on Jan 23, 2009
  • 44 Answers
I recently had this happen to mine. The caps were leaking, and had to replace the tuner.
Posted on Jan 15, 2009
    Scholar:
  • 87 Answers
Model Number: WS-55511 v21 chassis
Symptom: NO POWER
Cause #1
1. CHECK FOR 12 VOLTS DC (AC-OFF DETECT) AT PIN 3 OF PC9A21 IF LOW OR MISSING REPLACE PC9A21 PART # 268P058020 ON THE POWER PCB.
Symptom: SHUTDOWN AT POWER
Cause #1
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
    Sergeant:
  • 233 Answers
Hi there!
It sounds like you have a common mitsubishi problem, this could be the dm module. - I have a page here you should look at - it has some GREAT information regarding your particular problem!
http://www.techlore.com/forum/thread/16623/Mitsubishi-WS55511-will-not-turn-on/
  • 10,594 Answers
Please download Service Manual from HERE, it is free. Download all 3 files on website.
Service manual has all technical details and schematics for this TV including troubleshooting.
After having schematics, let me know to proceed further like check voltage of what part and where it is located.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jan 15, 2009
    If you rejected this solution again, you will see my comments after few more posts.
    Please check +B voltage at Power Supply section as its been marked in below exploded image of chassis.
    many times DM Power supply board got problem of capacitors and requires replacement of all caps. as shown in below image..
    As you have service manual and schematics now so let me know out comes to go further.
    Thanks.
    Now below is power block showing complete power supply. Please check what voltages you are missing in TV by help of schematics.
    You are welcome, any time.
    Genius:
  • 1,199 Answers
I would now check the power supply
  • 4,806 Answers
Hi there
Try to reset the system as below
If the TV doesn’t respond to either the remote control or the front panel controls
will not power off, press the SYSTEM RESET button on the front panel with a pointed item like the point of a ball
point pen or end tip of a paperclip.
The TV will turn off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing,
you may turn on the TV again. The changes you made while the TV was on before you used the SYSTEM RESET
button may be cancelled, however, the changes you made previously are not cancelled. Only those changes since
the last power on may be lost when the system reset button is pressed. All other settings are retained
Good luck and thanks for using Fixya
  • Lee Hodgson
    Lee Hodgson Jan 15, 2009
    It could be the programming on the remote control because you have replaced the IC board and a few capacitors, now you may have to enter the codes for the various A/V channels into the remote, then try again
    Refer to your manual for the right codes
    Good luck and kind regards
    Sergeant:
  • 378 Answers
Its the short tracking on the board itself due to some moisture or also check all main junctions on the board with onm meter for the proper voltages.
  • machine83 Jan 15, 2009
    this is the details i found for code 22 on one of tv repair forums.adding it for some more help to you.:
    error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this. we need to test some parts to see what this is. the most common is a shorted convergence circuit
    Top Expert:
  • Mitsubishi Master
  • 77,202 Answers
I have done this job and I will bet u have damaged the board, very, very easy to do.
Powers on & immediately off
On the middle board there are three green ceramic pico fuses
12_31_2011_7_11_11_pm.pngIf you know how to test them, then test them. If not, then just replace them. They are something like 5 for a dollar. They protect the image side of your TV from the power side. Some people have trouble with the capacitors, but I have never seen it happen. Chances are that you can fix it for a dollar.
Dec 30, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Will bad convergance ic's keep my Mitsubishi
If one of the two stk-392-570 chips has shorted it will blow a pico fuse on middle board and set will not come on.
Plug set in, turn on, when green power light goes out on the front of the set press and hold both the menu and input (device) buttons for at least five seconds and release both.
Power light will blink a two digit error code: if 2,2 it is a blown pico fuse and the chips also must be replaced. I have start to finish step by step instructions that are available if the customer selects me to answer in the new Marketplace here on Fixya.
see attached photo of chip and also part of middle board with the green pico fuses.
10_4_2011_6_10_21_pm.jpgchips look like this but will have 570 number on them.
SD TECH
Oct 04, 2011 | Mitsubishi Televison & Video
Hi there i replaced my hitachi 53uwx10ba convergence IC (2) stk392-120 and now it won't turn on and just flashes at the front panel 7 times, can i get some help pls
Did u check the pico fuse and all those resistors on the tv convergence board to make sure with ones are good resistors which are not good resistors and replace all them resistors too?U didn't do that should get it tested and replaces all those dying resitors.Try website like Tvrepairworld.com look up ur Hitachi tv model what resistors and pico fuse u require to check.
Aug 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I have a projection TV model ws-55909 that will not turn on. The timer light blinks for ten seconds and then shuts off?
the problem on ur tv could 2 problems , if the keep blink all the time is the digital box the problem to fix the digital box u have to replace 7 capacitor on the power supply inside of this box , now when u press power and the blink on then goes off the ploblem is going to bo the convergence ic pl;s 2 pico fuses part #stk392-570
Dec 02, 2010 | Mitsubishi WS-55909 55" Rear Projection...
Mitsu WS-55859---turned off & only powers up for 2 secs
2,2 is short protection.
98% chance the fuse or fuses (there are two 5 amp pico fuses) that protect the convergence circuit are blown. If you find F9AO4 OR F9AO5 on that board check them--if either is open the STK-393-110 DID IT.
Fairly short life for this chip if it was installed correctly and had heat sink compound applied to it--once in a while you get a bad one.
If this has helped you, rate this solution as I do this here for FREE.
sd tech
Nov 19, 2009 | Mitsubishi WS-55859 55" Rear Projection...
It will turn on sometimes and then it wont...The stand by light just flashes
First CK pico fuses around the convergence ICs big black ICs they look like resistors will be yellow or green also CK small blue capacitor behind hori out put transistor 2kv i have seen them have small burn hole on them, You may need to replace both of your STK ICs.STK394-570? Look on them they will have P/N on them. How many times does it flash before turning off? you can find out By typing in Understanding Sony Blinking Codes.
Aug 21, 2009 | Sony KP-51HW40 51" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Jul 27, 2008 | Mitsubishi WS48511 48" Rear Projection...
Akai pt4299hd
replace your STKs big black Ics STK394-250 there is 2 of them thses are your convergence ics.Also ck resistors and pico fuses.
Jul 22, 2008 | Akai PT4799HD Rear Projection Television
Same as everyone green light comes on for a couple of seconds than back off!!!
ok, the problem with short detect....
unsolder all convergance ic's and try to turn it on.
does it come on?
if no, check all diods in the power suppy area.
check h-output
does it come on?
also might have a vertical ic.
mmm, check all fuses including the solder in pico fuses.
beleave they are sold green color.
when i get one that comes in they have 1 or 2 blowed pico fuses and that means convergance ics need replaced along with fuses.
good luck!!
Apr 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
