Question about Philips Magnavox Learning Universal Remote
Remote died, cant change channel
My Magnavox (1990) remote died, the channel is stuck on 34. I need to change it to 03 so I can see TV. How is this done by hand? Help
  • Anonymous Jan 20, 2009
    I need a code for my philips universal tv remote. I have an old magnavox tv. help!
  • Anonymous Jan 21, 2009
    stick it in your ***
Call a geeky friend
Posted on Jan 17, 2009
Cant get to channel 3 on my magnavox tv
If set has a menu button go to menu and find auto program and program channels with it.
Otherwise you need a working remote to enter 03 and get back to that channel.
Mar 13, 2012 | Televison & Video
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox converter box and tv preset channel
Have her take the remote and hit 03. Alot of people think hitting the 3 only will work. Not the case have to hit 0 then 3.
Jan 11, 2009 | Philips PM-DVR8 Remote Control
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Philips/Magnavox 32MF605W/17 32" LCD Wide Screen HDTV ready w/ATSC.
Yes you can. This TV has both VGA-In and component in support. The only thing you need to change is the input you're using with your remote control. As easy as changing the channel!
Oct 15, 2007 | Philips Computers & Internet
Philips Magnavox Learning Universal Remote Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
