D-Link AirPlus DI-524 Wireless Router Logo
Farheen Syed Posted on Jun 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with set up
I have a wireless router of D-link DI 524 and my bro gave me his wireless Range extender DWL - G710 actually i dont knw how to go about with it can any one help me guide how to set up the extender so i can used my laptop in my room as well now im just bounded to one room because it doesnt work at all :( is it possi tht its useless ????
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jun 17, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
6300
Points
12
Make sure the extender DWL - G710 has the proper connection to the back of the router. if not the signal will drop out.
Anonymous
Level 3:
President:
  • Master 2,961 Answers
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1638374
Points
8444
It should be easy to set up unless it's faulty, it's a case of setting it up throug a web based menu through your internet browser; but to find instructions on how to set it up, you need to look underneath the extender for the version and then click on the link below:- http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVTALoeU8H8g50JcLpcX43jIuejxxi6E4R7gbckLJIhMa5i7DQlHA==
3helpful
2answers
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Got a DWL-G710 wireless extender that will not
First I would try a reset, as this extender should would with your default settings of your network.
I would suggest just giving your router a reset. Here are the procedures for your particular router:
Reset Procedure
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
make sure to setup your wireless security again and make sure to set an admin password on your router after the restart.
Different router and extender signals
you are seeing your neighbours wireless as well. hook up to the one that is your router/provider
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
2answers
No internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
4answers
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
1helpful
Router Configuration in "Wireless Client" Mode
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
