Question about Nikon Coolpix 4300 Digital Camera
System error my camera suddenly has a frozen lense and says "system error" on monitor. I can still view photos taken on my memory card, but once I put the dial in the mode to take pics, it says system error. The lense is out and will not move back in even when I switch the camera off. Have removed battery many times (as suggested in troubleshooting of manual,)with no luck. Anyone solved this one before.
  • bob humphreys Jun 18, 2007
    Have just checked nikon tech support as you suggested. They say can only be fixed by Nikon so will need to be sent to them for repair.(which would cost more than buying a new 4MP camera these days!) Appreciate your time.
    By the way, this is what Nikon Tech support said. (using the original memory card and replacing the battery didn't help me but may help someone else so here's what they said.)
    "Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
    Use the memory card that originally came with the camera (or a Nikon approved card)
    Remove and replace the battery
    If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras."
Hi, my camera has been doing this for two years off and on, more often lately. I also found the lens sticking when vacationing somewhere warm and humid and tropical. I ususally fix it by gently pushing on the lens as I turn it off. It may take several times for the camera to correct itself. I found this website hoping to find a better solution to this problem, too, it sounds like the only solution is to upgrade to a new camera. Too bad, I love my 4300 and have been very happy with the photos taken. But, having a camera that can take 7mp and up is attractive and for the price of repairing this one. Hope this helps.
Posted on Jul 07, 2007
    Genius:
  • 2,985 Answers
This is fundamental break down and may not be repairable. Check out th Nikon Web site technical support
Posted on Jun 17, 2007
  • Anonymous Jun 18, 2007
    This applies to pretty well all so called 'consumer' cameras.
    There are no parts to replace.
    If you send it to Nikon they will replace it with a reconstructed model of the same.
    As you say for a few bucks more you can get the latest version- So that seems the thing to do
SOURCE:
I have always taken my memory card from the camera and placed in my computer to download the phon
Try to use your camera and usb cable to recover any picture that's there. You need to format the memory card. Scan for errors. Fix it.. format it again inside the camera. And then also try to check for any updates available for your laptop drivers.
Apr 06, 2014 | Fuji Cameras
Unable to view photos i have taken, Screen says Read Error
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 16, 2012 | Fuji FinePix Cameras
I Have taken pictures with the camera , after it saves it keeps telling me photo error , im trying to recovery images i have taken , and they are unable to view and when i copy them to my pc , windows says...
Your pictures may be corrupted.You can recover those corrupted pictures with this
1. Do not save any new pictures into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
How to Recover Deleted Pictures from Digital Camera's Memory Card?
Aug 22, 2011 | Vivitar ViviCam 5385 Digital Camera
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
My screen suddenly is just white with no picture?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car after removing and replacing the memory card and powering off then back on your cam, you may see how the system now registers your photos will having to click back and forth between AUTO and MAN. I posted very closely related troubleshooting steps to take in order to prevent your CAM from performing badly. Check your CAM batteries to ensure they are using only approved NIKON batteries as anything else will cause you lots of errors and potential problems. When you using the timer or remote options, remember these are controlled by battery as well, radio frequency, and radio wave lengths. When you press the button to take a photo, inspect the button, press firmly for a second and release. If your button is not performing the way it should, inspect it to see if any wear and tear is visible to you. Check free deprey around the button such as DUST, HAIR BUILDUP, and small particals that are hardly visible to the human eye. With very low velocity pressure air, blow around the shoot button as build up will cause the same error your experiencing.
Jan 26, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
The card is not locked.The other message is Memory card error. I have tried two cards they both get the same message, but when I put in the one that came with the camera a 16mg card , it works fine
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car after removing and replacing the memory card and powering off then back on your cam, you may see how the system now registers your photos will having to click back and forth between AUTO and MAN. I posted very closely related troubleshooting steps to take in order to prevent your CAM from performing badly. Check your CAM batteries to ensure they are using only approved NIKON batteries as anything else will cause you lots of errors and potential problems. When you using the timer or remote options, remember these are controlled by battery as well, radio frequency, and radio wave lengths. When you press the button to take a photo, inspect the button, press firmly for a second and release. If your button is not performing the way it should, inspect it to see if any wear and tear is visible to you. Check free deprey around the button such as DUST, HAIR BUILDUP, and small particals that are hardly visible to the human eye. With very low velocity pressure air, blow around the shoot button as build up will cause the same error your experiencing. I SUSPECT THE NEWER CARD IS NOT COMPATIBLE AS THE OLDER CARD IS
Jan 25, 2011 | Canon PowerShot A610 Digital Camera
My g.e camera always indicates picture error when i try to view
taken photo might have not stored well,memory card/card reader problem so clean chaqwue and adjust.
Mar 16, 2010 | GE A730 Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
217 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
