Question about K2 Cinch CTC Snowboard Binding
Rear leg high back comes undone/releases when i pop
I ride goofy and when i 'pop' off rollers or just ollie over things, my left high back automaticly releases! i haven't adjusted them in any way for this to suddenly start. they are the carbon 07 model. this is a major problem as it is highly dangerous as my back foot can and will come out of the binding, because as i'm 'popping', my feet are pulling upwards and thus out of the now open binding. it's only a matter of time till it happens at high speed off a roller and i have a serious wipeout!
    Problem Solver:
  • 4 Answers
It sounds like either one of two things, with the high back. Take the adjuster off and check the teeth to see if it is stripped. If it is, Go to your local hardware store and pick up some locktite epoxy. It will be a permanent bond, but that will make them usable. The other chance is maybe it needs to be torqued down. With the possibility of your foot popping out that sounds like you bindings are not set up correctly. I had a pair hit a rock off a bc kicker, ripped the adj, off. and still was securely held down. If you are not sure how to set it up, hit up your local board shop
Posted on May 08, 2009
We've got a noisy Maytag gas dryer and it has been suggested it needs brake shoes on the front and rollers on the back of the drum. Is anyone near enough to Oberon to assist us please?
To access the front you remove 2 screws at the base of the front and remove the front panel, newer models you pop the top first. Not all maytags are exactly the same. The front of the drum rides on plastic glides and the rear of the dryer rides on rollers. I made a few maytag dryer home videos HERE
Jul 23, 2012 | Maytag Dryers
Are back feet/rollers adjustable?
normally the rear are just rollers
for your problem use tapered door wedges ( hardware shop) under the appropriate side at the rear of the fridge to make the adjustment
Sep 04, 2017 | Electrolux EI23BC51IS
How to replace the roller
  • Tray 1 Pickup Roller Replacement
  • Turn off the printer and unplug the unit. Remove the following doors: the DIMM cover, rear cover and top cover.
  • Open the door to the area housing the toner and remove the toner cartridge. Set it aside. Release the toner drive arm located at the right side of the toner door.
  • Locate and remove the screws at the front left and right corners on the top of the printer and the two screws at the right and left at the top of the back of the printer.
  • Locate the latch at the left side of the hinge for the toner door. Release this latch and then remove the door.
  • Pull out the old pickup roller and replace it with the new tray 1 pickup roller. Reassemble the printer.
  • Feb 21, 2011 | HP Office Equipment & Supplies
    Says its out of paper, I put paper in it but when I open the folder to view printers, it says it is still out of paper
    Hi!
    Please clean the rollers of the printer this problem is caused by dirty rollers....
    Follow these steps to clean the paper rollers.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Disconnect the power cord from the rear of the product.
    3. Remove the rear access door.Different models have different rear access doors. Some have one release tab, some have two release tabs, some have a knob to turn, and some have in-tray catches. Some also have automatic two-sided printing accessories (duplexers). Release the rear access door or duplexer as necessary, and then remove it to access the paper rollers for cleaning. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif c00104514.gif Product with a rear access door release knob Product with in-tray catches c01964197.gif c02297019.gif Product with a duplexer
    4. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward carefully to clean all the way around. Figure 1: Paper rollersc01438859.gif
    5. Allow the rollers to dry completely, and then replace the rear access door or duplexer.Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
    6. Reconnect the power cord to the rear of the product.
    7. Try printing again.
    Aug 21, 2010 | HP Deskjet D4160 InkJet Photo Printer
    How do I adjust the belt on my Proform Crosswalk Gtx? The belt is too far to the left on the rollers. Thank you.
    You can adjust the rear roller bolts tighten the left side to make the belt come back to the right. If it will not come back you may have a broken endcap causing the problem
    Aug 09, 2010 | Treadmill Doctor Proform Crosswalk Gtx...
    Open door and whole unit moves, it dosen't come with back legs, or does it??
    No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
    You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
    Hope that helps,
    Good Luck
    Oct 31, 2009 | Kenmore 60721 Refrigerator
    Makes a horible noise like spinning out of balance
    All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise.
    Oct 20, 2009 | Dryers
    2000 Grand Prix GT - Parking Brake Stuck - Immediate help needed!
    If it is not automatically releasing the park brake wnen car is started and put into gear there may be a more serious problem , There are also break release handles in the area .
    Oct 02, 2009 | 2000 Pontiac Grand Prix
    Off balance
    make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
    Dec 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
    Top rack keeps slipping off of tub rollers.
    I was sold this model and had the same thing happen.. However when calling for service, my service rep would not come out, so I contacted Fridgidaire and provided the model and serial # of my unit and was told I was sold an unrepairable unit that had already been returned for service for the same thing and considered unrepairable and was no longer under warranty. When my supplier finally came out he put new longer rollers in my dishwasher, but when I mentioned what Fridgidaire had told me, he went back to his supplier and they got me a new one. Being installed today.. The new one is a PDA2855 model as I am told that the PLD2850 is no longer sold.
    Mar 31, 2007 | Frigidaire 24 in. PLD2850 Built-in...
    K2 Cinch CTC Snowboard Binding Logo
    162 people viewed this question
    Top K2 Winter Sports Experts
    Arnie Burke
    Arnie Burke
    Todd Arndt
    Todd Arndt
    Are you a K2 Winter Sport Expert? Answer questions, earn points and help others
