Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Refresh database freezes
Hi i bought a sandisk mp3 player model: sansa c 250 and ive put some music in it but everytime i turn it on it says "refresh database", it starts refreshing at one point but stops at less than half way... I left it on 2 whole days but its still the same. Is there anyways i can reset it or erase everything? If not can you tell me what to do? thank you for your time...
  • 5 more comments
  • yitatasuni Nov 11, 2007
    I have the exact same problem. The referesh database freezes up for a long time. When it finally unfreezes, none of the mp3 files are there.
  • Ashlyno Nov 16, 2007
    I have the exact same problem as you. I start up my player and it loads fine.... The bar in the Refreshing Database part is moving. It gets about half way done and then the screen turns either white, green with darker green bricks moving down it, or blue with darker blue bricks moving down it.... I have absolutely no idea what to do.
  • Anonymous Nov 22, 2007
    my sansa mp3 player keeps freezing on the refresh database screen. I can't do anything, not even turn it off. What can i do?
  • Anonymous Jan 19, 2008
    Help!! My database keeps freezing at 75% and I have tried everything.
  • ezmp3fix May 19, 2008
    ive tried downloading the firmware and it all downloads but it still freezes at like 60percent.LAME-0
  • Anonymous Nov 08, 2008
    Sansa c250 freezes on "refreshing database".
  • Anonymous Mar 03, 2009
    i had the same problem, but only when i use my micro sd card without the card it works fine but wont hold al my music. what can i do????
    Scholar:
  • 155 Answers
Try updating the firmware of your player. Switch the player to recovery mode (enable hold switch and press and hold the record and power button until you see on the screen welcome to recovery mode) download the sansa firmware updater on the sandisk website and install it to your computer. When it ask to connect the device connect the player and check if there are updates on the player. Also try to format the player it may be the songs on the player is causing the problem.
Posted on Jul 22, 2007
Were can i get the sansa firmware
Posted on Sep 15, 2008
SOURCE:
Sansa e270 freeze if switch on,it indicates,REFRESHING DATABASE"
Having gone over a month with no response, I assume the reset solved the problem.
Jul 08, 2010 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
(e260R) Refresh Database eternal loop
Turn it on into recovery mode (Hold + Record Button + Power)
Connect to computer (You should detect a 16MB drive)
Make an empty text file inside the 16MB Drive and rename it to "sansa.fmt"
Unplug the Sansa. You should see now a "Formatting..." on the Sansa's screen.
Sansa fixed!
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Add music and refresh database to sd card
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Aug 10, 2008 | SanDisk Sansa e200 MP3 Player
Sandisk sansa e260 refresh database error
is there a reset butten somewhere on it well if it is then get a paper clip and un bend it a press rest and then turn on your sandisk sansae260 and see what it say and maybe that will sovle your problem Have a great happy fun day
Jul 20, 2008 | SanDisk Sansa e260 MP3 Player
Sansa
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh database on screen
how do you put on recovery mode?
Dec 01, 2007 | SanDisk Sansa e260 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
702 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
