Question about Kenmore 62882 Electric Dryer
Dryer runs for 15 minutes and stops
Dryer Kenmore runs for about 15 minutes and stops have to wait about 10-15 minutes for cool down I've replace thermostat cutoff motor and hi temp switch driving me nuts
  • asac_snooze Jan 16, 2009
    i changed it and now it still stops any other ideas
  • asac_snooze Jan 17, 2009
    it is working on the temperature dry and on medium heat perm press but on high heat it stops after 15-20 minutes and the same problem
    Problem Solver:
  • 16 Answers
Check the in-line limiters on the heating coil tube.
Posted on Jan 15, 2009
  • Steve Jan 17, 2009
    Check and see if there are any more in-line limiters. If not, sounds like you have a bad timer motor(missing an internal gear)Let me know.
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
I have a kenmore 80 series dryer. 18 years old. Makes loud buzz when starting and overheats and stops in about ten minutes. I've bypassed thermal fuse and samething happens. I've also cleaned out...
You don't want to bypass the thermal-cutoff. If the thermostat is malfunctioning, it WILL overheat and cause a fire!! For the age of it, I would replace the whole dryer! It's going to cost you more in time than the value of the unit.
May 21, 2012 | Kenmore Dryers
My kenmore dryer 66512692 runs for approx. 10 minutes and cuts off. I can come back to it usually a couple of hours and it will run for another 10 or 15 minutes and stop. It will complete the Air Dry...
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
wer
Dec 25, 2010 | Kenmore Dryers
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Sears Kenmore 08980800 Stops after 10 minutes of operation.
Sounds like the motor may be getting hot and kicking out on the motor overload switch. When it cools down it will reset.
Jun 10, 2009 | Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Kenmore 62882 Electric Dryer Logo
265 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
