Question about Palm Treo 700w Bluetooth GPS GPS Receiver
Problem setting up bluetooth device with Palm Treo
I have a Palm Treo (700 or 750, not sure) and I am trying to set up bluetooth with a handsfree devise (BlueAnt) for my car. I go through the steps as directed, but can't make it past selection of the device. Once I select it, I have no prompt to put in the security code and it will not add it to my trusted device list. Is it a problem with my phone or the handsfree device I have (BlueAnt)? What do I do?
-Nicole
  • 49 Answers
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Posted on Apr 09, 2010
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
I am trying to connect my palm treo with my lg keybo 2 using bluetooh in order to transfer my phonebook. the keybo finds my treo but when prompted for the passkey at the pairing window it always fails. I...
LG has a couple bluetooth keyboards. do you have the model number?
by the way are you pairing the keyboard to the treo or the treo to the keyboard?
normally there are 4 zeros are the normal passkey numbers for the keyboard
Nov 29, 2009 | Cell Phones
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Setting up headset with treo
Not sure which Palm Treo you have, but after reading through some of the info on the different sites it states that some bluetooth devices were easily installed and others were not. It may be one of the Treo's that may need an application to download an update. Some of these were released according to the information I read, that did not have DUN installed. Whether this has anything to do with pairing your bluetooth device, I am not sure. I couldn't find a spec page for your application. Usually it is just a simple matter of going to the bluetooth application on your phone and turning on your bluetooth headset. They find each other and you have success. I would recommend talking to Plantronics tech help line at 800-544-4660 x 5538.
Good luck from Headsets Direct!
Sep 12, 2008 | Plantronics Explorer 330 Headset
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
stephen
Jul 05, 2008 | Palm Treo 700w Smartphone
Palm Treo 650 doesn't see bluetooth headsets, AND wired headphone jack is shorted
Had a similar problems. Throw out wired headsets with shorting problems. Their too cheap to try and fix.
Try rebooting the phone, then make sure the wireless headset is on. The trick is to get it into "trusted devices", so when you get the phone to seek new or nearby devices, you need to push the button on the earpiece so it sends a signal at the time the phone is trying to find it. It took me a number of trys, but finally got it to work. I use Verizon and they were quite helpful, even though the phone was "out of warrenty". I was re-activating my phone after not using it for a couple of years.
Mar 08, 2008 | Palm Treo 650 Handheld
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
MOBILE PHONE NOKIA
Jan 28, 2007 | Plantronics M2500 Consumer Headset
GPS Logo
143 people viewed this question
Top Palm GPS Experts
Will Halftowaite
Are you a Palm GPS Expert? Answer questions, earn points and help others
