Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
Open display In the date and day display area the word "open" keeps being displayed. This prevents me from using any other functions. how do I get the watch to perform as normal
    Problem Solver:
  • 5 Answers
This is not a documented function of the watch in the user manual to be found at http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2767.pdf Also I have this watch and it has never done this.
It sounds to me like either watch case is not closed properly or there is a fault with the CPU of the watch.
Posted on Feb 19, 2009
I have an Armani watch ar6049. The date goes way past 31 to at least 35. I have never seen a watch go past 31, what gives??
There are Mondaine watches that do the same thing. I believe that it's because the date display is actually two separate disks, each reading 0-9. Most date watches only have a single large disk for 1-31. Although your watch is capable of displaying, for example, the 33rd of the month this doesn't happen in practice as the logic built into the watch prevents it.
I assume that using 2 smaller disks to display the date, rather that 1 large one, is for design purposes - possibly it would get in the way of additional hands or other features on the watch.
Hope this helps.
Sep 02, 2017 | The Watches
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Apr 29, 2014 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
Dec 18, 2011 | Cerruti 1881 Watch
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Feb 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Setting Date & time
mcdevito75 here, generally you need operate 2 bittons to set your Casio watch, the MODE and SET buttons. Press the Mode button, you may have to hold it in for 2-3 seconds, see the display falshing, press MODe to go to each function, once at the function you want to adjust, press SET press MODE to move onto next function, once all functions are set, press MODE for steady display. If this fails, look for a small watch repair shop in your area for help setting up the watch.
Feb 11, 2011 | Casio Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
Trying to set the time and date on my fossil dq-1128 watch. help!
mcdevito75 here, Press the mode button, you may have to hold it down a couple of seconds, once you see the display flashing press set for each function, after each function is set press mode to move to the next function, hour, minute, day etc. Once all functions are set press mode for steady display. NOTE, the mode button could be a small dimple not far from the winder crown, use a tooth pick to presss this dimple in.
Nov 19, 2010 | Fossil Watches
Casio waveceptor watch, how do i reset it
mcdevito75 here, 1 of the buttons should say MODE, press this button and see the display blinking, NOW! press the set button for each function, after each function is set press MODE to move onto the next function, when all functions are set, press MODE again to see steady display.
Jul 01, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
334 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
