Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Freezer is cool but not freezing or making ice - fridge not cold
Hello! My GE side-by-side is not freezing and frost is building at the back (inside). It won't make ice, but I am still getting water from the dispenser.
The fridge side is not cold enough and things are spoiling faster. The freezer is actually at about the temp the fridge should be.
The fan is still running and I have cleaned all the parts I can get to in the back, but it still won't function properly. I haven't heard the compressor come on or off in a while.
I would really appreciate any help you can give me! Thanks!
  • jspondike Feb 12, 2009
    I have the same exact problem. I am pretty good with a meter, and need to know if a schmatic is availible...What are the chances it's the main board? Defrost Heater, Defrost Sensor, Defrost Timer - are all these replaceable without calling out a service technician?
  • Anonymous Mar 17, 2014
    replaced circuit board after repair guy said it was bad worked great for a month then it stopped making ice and fridge and freezer dont get cold enough and frost buit up on back of freezer
    President:
  • 1,214 Answers
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Posted on Jan 15, 2009
MrMark52 - I unplugged my frdige overnight, and pluged it back in and everything works fine. The lower part of the fridge tend to freeze up, but it works for now. Thanks - John
Posted on Feb 14, 2009
  • jspondike Jun 16, 2009
    The problem continues...Unplugged for a few hours, and all works. PLug back in for a day or two then the freezer doensn't make ice, the whole unit doesn't stay cold enough. Any ideas?
james3751
  • 614 Answers
SOURCE: Snow build up inside the dispenser
There is only so much you can do. But the problem is the gasket inside that seals around the opening where your ice is dispenses is bad. You need a service tech to replace gasket. If you want to try get the model and serial number and take it to an Appliance parts house and tell them you want dispenser seal gasket. You just tell them what its doing and most of them know exactly what you want. Rus
Posted on Jun 21, 2009
aasc
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Posted on Jul 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Posted on Aug 14, 2009
woodchuck789
  • 4070 Answers
SOURCE: bad frost keeping building up around ice dispenser
This is usually caused because the door is not shutting all the way or not tight allowing air in.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Posted on Sep 21, 2009
Testimonial: "Very helpful info, until now I did not know I could take out the ice bucket, there was a lot of built up ice behind the bucket.Thanks very much. "
SOURCE: frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
Posted on May 27, 2011
GE concept 2 fridge/ freezer combo. Freezer suddenly stopped freezing anything . It's cool, not even as cold as the refrigerator part. Any ideas?!
Hello:
Check if there is any frost buildup on the back wall inside freezer. Maybe your defrost system failed and ice is blocking the air flow(no air flow you just got a cooler )
Jul 07, 2017 | GE Refrigerators
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Fridge doesn't cool.
Hello, would you happen to have the make and model number of your refrigerator? In a refrigerator the freezer side of the refrigerator is the only side that produces the cold. If your refrigerator side is not cool but your freezer side is one of the first things that you would check would be to open the freezer door and look along the rear wall of the freezer to see if you notice any frost or ice build up on the rear wall. If you did this is termed as a defrost issue and message me back that you do have this situation and I will instruct you how to diagnose this to correct this situation. If you had no ice/frost build up on the rear wall you would next assure that the evaporator fan is blowing air inside of your freezer. If you felt no air blowing inside of the freezer you would then remove the rear wall on the inside rear of the freezer by unscrewing the 1/4" screws. This would give you access to the evaporator coil and above the coil would be the evaporator fan motor. I will await your reply to your finds as to if there is any ice/ frost and if the evaporator fan is blowing air inside of the freezer before further diagnosing.
Thank you
Rick
Oct 25, 2011 | Refrigerators
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost building up inside freezer.
Hi: Make sure your vents are not blocked by too much product in the freezer. When you changed the heater did you take a hair dryer to the back to make sure the initial blockage of frost and ice was removed as that will still block the air flow to the referigator, and cause frost to build? Also if the frost isn't in the back of the freezer but on the food it means there is a bad door seal. Usually the frost will look like snow flakes. The timers are on a circuit board now. And expensive. Ge makes an excellent refrigerator, but the parts are high in price. I hoped this helped. Jeff
May 31, 2009 | GE GSS23QSSS
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
996 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
