Question about iLO 3200 32 in. LCD Television
TV-not working Hi! Two days ago out of no where-our tv will not change channels, turn up/down volume, change from cable-dvd, or anything beside turning off/on. We have tried to unplug-replug everything.....nothing works!!!!
    Problem Solver:
  • 5 Answers
How about the buttons on the side of the tv?? work?? if so the trouble is in the remote: if they don't work either, the trouble is in the set = goose cooked-- sorry
Posted on Jul 04, 2007
SOURCE:
How can I change to channel 3 to view cable?
The TV has no manual channel change buttons on it? I have never seen this on any TV ever.
Mar 19, 2016 | Sylvania 6513DF 13" TV/DVD
Tv will not change channels. Batteries are new. It worked fine 2 days ago.
If the remote you are using will control several devices (TV, DVD player, cable set top box, etc.), make sure you have pressed the TV button, before you try to change channels. Sometimes another device button gets pressed by mistake, so the incorrect codes could be sent to the TV.
Mar 15, 2016 | Televison & Video
Hi, i was trying to turn down the volume on my tv (its an insignia) and i accidentally hit the channel button and i think it messed up the programming of my tv to my cable box. what should i do?
try setting the tv to channel 3 or 4. if that does not work, try finding a "input" or "source" or video" button on the remote and cycle thru them, this should get you back up and running. remember to have the cable box turned on during this so youll see when it comes back on.
Mar 24, 2011 | Televison & Video
I have a Spongebob tv/dvd player. When trying to
I looked through the manual and didn't see anything either. I assume that you are hitting the TV/DVD button and setting it to DVD when you want to use the DVD. Does the remote do anything besides turn the TV on (change channels, etc.)? Hope this helps and good luck!
Mar 15, 2010 | Emerson SpongeBob SquarePants TV
TV doesn't turn on
I have a Mintek DTV265 which is almost the same TV the red light don't blink it stays on as long as the Power button is on. Try turning on the TV by pressing any of the buttons on the side of the TV Channel up or down, Volume up or down , or source. If it comes on then your TV is alright. I had one of them jumbo universal remote controls and it actually had a code that worked on my TV.
Mar 02, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
iLO 3200 32 in. LCD Television Logo
83 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
