Scanning problems.scanner works just fine the problem is me
Hi, after the item/s are scanned you should be taken through a series of prompts, one being to save the scanned item/s. Can't tell by your description at what point you are having trouble. So I may be covering some areas you may already be familiar with. After you have saved item/s to a location where you can access it, depending on how the item was saved, such as in the Windows and Fax Viewer or similar. If you are using Microsoft Windows that is. Place cursor over the saved file, right click and place cursor over "Send To" where a drop down menu will have some options, select "Mail Recipient" and it should open up your preferred email program with the item/s attached ready for you to enter the email address where you want to send it to. If not then open your email program that you wish to use and select the option to write send or compose mail depending on which program you use, select "add attachment" then select "Browse" and when you locate the item right click it and click "Select" which should place the item/s into an attachment.
Hope this helps. Ratings are very important to us so I want to thank you in advance for taking a moment to rate my response.
Matt
