Question about Home
Toilet keeps flushing itself, its is a bemis toilet. its been doing it since i put sum of that bloo stuff you get although i took it out straightaway.
  • 4th gen plbg May 11, 2010
    Does it totally flush, or do you hear the water filling the tank back up?
    President:
  • 2,692 Answers
Replace the flapper. It seem to have been damaged. It that does not cure the problem by itself you may have to replace the flapper seat also.
Posted on Jan 20, 2009
I have a Kohler Toilet K 3400 which has been leaking with a little stream of water entering into the tiolet bowl it self, I bought a Kohler replacement kit # 30166 ( one part that I did not replace in the kit was the part that has to be screwed in and removed by means of a Allen Key, only because it's hard to remove out ) and it leaks more then ever now and noisy let a lone wasting water too, I replaced the # 51230 Flush Ball also - adjusted the Float Ball for the water level - yet it keeps on having a stream of water entering the tiolet bowl - I would not like to buy the entire hardware it's self because it is costly -please have any Idea what to do ? Thank You Andy !
Posted on Nov 01, 2009
Bemis two-flush toilet occasionally flushes by itself. How do I fix that?
Probably the flapper is not sealing, allowing leakage into the bowl. When the level in the tank drops sufficiently, the fill valve admits water to refill the tank.
Jul 04, 2017 | Bemis Home
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
Vitra cistern parts
it could just be bad water pressure how are your cold taps in the same room?
have you used bloo loo type things in your cistern? there may be a blockage in your inlet or a build up of lyme.
check this
Jun 17, 2013 | Home
Where can i get seaat for my ssww toilets they crack all the time
Go online and look for some bemis toilet seats, they are great seats.
Oct 09, 2012 | NRS Royal SSWW 1012 Dual-flush 1-piece...
Toilet water is too high after flushing
hi!kindly adjust your fill valve so that the water will not overflow to your tank.
Aug 21, 2011 | Bemis Home
What do I do to stop water from leaking from the tank, it refills itself several times, day or night? The toilet looks like a Sedona, although the shape of the tank differs a bit, the width is the same,...
Sounds like something in the floating device is bad so it doesn't shut off when filled. We just replaced our flush valve on ours because the toilet keep running.
Jul 11, 2011 | Toto Toilets ST784S 12 Sedona Beige...
What toilet seat hinge replaces Bemis elongated closed front toilet seat (plastic/not a bar/pair of hinges) and who sells? Can't believe Bemis does not support to proclaim hinges set in warm plastic...
The hinges and bumpers on plastic seats are not replaceable. The bumpers are molded in and the hinges are installed with special tools while the plastic is still warm.
Sorry but that's way Bemis does things and is way most good Plumbing shops will not buy or sell them.
They were not like that untill they started having their seats made in China however this may help you http://www.bing.com/shopping/search?q=bemis+toilet+seat+replacement+parts&FORM=HURE
http://www.bizrate.com/plumbing-supplies/oid1620858646.html
Mar 11, 2011 | Bemis 7MCLRDRCT NA Elongated Toilet Seat...
This bemis toilet flushes at least three times before it is finished. now it's stopped up with poop and a little toilet paper,we've been plunging it for about an hour and can't clear it up completely
A common problem. You have a partial blockage. If you have a plunger then you may be able to force the blockage out by filling up the bowl near to the top with warm water anbd filling it wit 4oz / 100ml liquid bleach and leaving it for 1 hour (not hot as this may crack the toilet). Then then plunge down several times until the blockage disappears. You may have to repeat this two or 3 times to completely clear the blockage. Also try filling up the bowl with pan with 10oz / 250ml liquid bleach and leaving overnight withthe lid down and the bathroom door shut. If you do not have a plunger use an empty 2litre or 80oz coke or plastic bottle, with the tope securely screwed on to maintain the rigidity of the bottle, so it will neatly fit the toilet cavity at the bottom without damaging the toilet.
Oct 26, 2009 | Bemis Home
Home Logo
1,485 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
