Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag French Door Refrigerator with ice and water on the door
I need to replace the high voltage board on the refrigerator as the lights on the door are continually flashing and the ice maker chute constantly flaps open and closed. Where is the high voltage board located and how do I replace it?
  • Anonymous Mar 19, 2014
    Not making ice
  • Anonymous Mar 22, 2014
    i have tried unplugging it and check all the doors
I had the exact same problem so HERE IS THE REAL SOLUTION: The first post by schwab is only HALF CORRECT. After the board is replaced it has to be programmed from the front digital display board key "+ and - keys" There is a code on the inside of the fridge that needs to be entered using the keypad on the front for temp adjustment etc and a specific sequence to set the program. If not done properly your fridge will not work but will look like it is. Call Maytag for FREE REPLACEMENT. They did mine. FG-Systems Engineer-I watched very closely what they did.
Posted on Sep 08, 2007
  • 4 Answers
See the post on Samurai Appliance Repair Man's site for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
Blinking display
jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Sep 19, 2007 | Maytag MFI2568AE Side by Side French Door...
We woke up this morning with the lights flashing and the ice maker shoot door clicking every 6 seconds and it won't stop. Any ideas how to reset it or get it to stop?
Your High Voltage control board has gone bad there are capacitors on the board that are bad and you can try to replace them or buy a new HV board.
May 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
you need to replace the high voltage board behind the unit , not he board behindthe dispnesor.. call maytag with oyur issue, tell them thatyou read about it oin the internet adn would like compenstaion for the board, form the numbe rof posts you read about!!!
Jan 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
533 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
