Question about Panasonic PanaFax UF-8000 Laser Fax
Panafax uf 8000
When you turn on the machine it makes a loud grinding noise the screen says papper jam
  • Paul Homuth
    Paul Homuth May 11, 2010
    for leroyal, one you dont have to replace the gear and the fuser. its one or the other very rare both and most time only the fuser
  • Paul Homuth
    under paper jam what what it say..
    fuser gear might not be busted and yes you might need a fuser.
    could be j01-j02-j43-j44 let me know which one it is please
    Genius:
  • 2,120 Answers
You have a broken FUSER GEAR, very expensive to get repaired because the entire machine must be torn down to the frame.
If you get it repaired, you might just as well get an entire new fuser. Estimate $500-$600.
Posted on Jan 16, 2009
I am having an issue with a Panafax uf-8000 printer. It grinds when starting up and says there is misfed paper. Don't see any.
Paper feeder sensor guide is open or displace ,So it said misfed paper.Clean sensor or right position set the sensor guide.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic UF-8000 has very loud sound when sending or receiving documents. Why?
This problem is mechanical,some of Gears were broken.Please check which gear was broken and replace it.
Grinding noise when engine runs, customer just changed the toner. Makes noise without toner in machine. The delivery output assm. not turning.
You have a broken fuser drive gear. Only a Panasonic Technician can fix this for you; because of the time involved the entire fuser unit should be replaced.
Nov 04, 2009 | Panasonic PanaFax UF-8000 Laser Fax
We use the Panafax UF 8000 only as a fax. Can we use it to scan?
The Network /Email Scanner Card is an option. You can, however, use the Panafax as a Network Printer.
The printer driver is on the Document Management CD.
Nov 20, 2008 | Panasonic PanaFax UF-8000 Laser Fax
UF-8000 jamming and not transmitting consistently
what exactly is the error code on your machine, and if you replaced some of the fuser parts already you might have pinched the ribbon cable by the fuser
Nov 04, 2008 | Panasonic PanaFax UF-8000 Laser Fax
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Gear grinding noise
Sounds like it could be the toner cart is not mating properly. Sometimes this could be simply that the spring and flap arrangement on the plastic case of the cartridge has become misaligned. It is not necessary to have the flap(cover) present once the cartridge is installed in the machine. Just remove it in it's entirety if you can't re-align it.
Jan 25, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
164 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
