The set should in owner manual have detailed instructions with diagrams etc.
Basic is from player outputs (whichever it uses) HDMI, component etc OUT to the same on the set(usually into a rear input) IN, select that input on the TV and if player good you should have a working system.
When you want to go to use the player select that input (most Mitsubishi sets will allow you to change from input # and label that input DVD etc--that's in the TV setup menu most of the time.
The more things you have connected to the set the more complex it can get.
SOURCE: vizio tv code for sony blu-ray disc player ''remote''
I put the Mitsubishi code, 04 as well for my visio 22 inch LCD. Worked just fine now!
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck [email protected]
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: Samsung Blu ray code for direct tv remote
is there any remote that i can program tv,cable,direct tv,and blu-ray player all in 1
