Question about Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049
Head bolt torque spec for this compressor
Need the head bolt torque for this compressor
    Problem Solver:
  • 19 Answers
220-300 in lbs work from center out
Posted on Feb 01, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
I need to know the correct torque specs for the 4 bolts that hold the a/c compressor on my 2003 Suzuki Aerio. In order to replace the water pump it was necessary to remove the compressor. The book supplied...
The ac compressor bracket bolts are to be torqued to 40 ft lbs, as far as the compressor itself you can just hand tighten bolts, there is no specs for compressor bolts just bracket, the bolts are just snug.
Aug 28, 2012 | Suzuki Aerio SX Cars & Trucks
Husky model VT631502AJ head torque specs
I am certain there are torque specifications but I don't know what they are. You might be able to get them from the manufacturer. Lacking that, determine what the bolt strength (usually indicated by marks on the bolt head) and with the bolt strength and size you can determine what the appropriate torque would be for that size bolt. Too little torque and the head will leak. Too much and you will strip out the threads or twist off the bolt head. A 13mm head is nominally a 1/2", which is not a very large bolt head thus the bolt shank is not going to be particularly large, probably somewhere in the 7 to 9 mm range. Check online for torque specs. If you can't identify the specific bolt strength I would assume it is the lowest normal value for that size bolt. There shouldn't be any particular reason for using high-strength bolts in this type of application.
Aug 03, 2012 | Air Tools & Compressors
What are are the tork spec on the clyinder head bolts
Torque setting for that cylinder head would be around 20 ft/lb and about 30% less if the bolt threads are lubricated before insertion.
Jun 22, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
220-300 inch lbs work from center out
Jan 15, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Coleman 6.5hp - 80 Gallon Vertical ASME Oil - Lube Air Compressor CV6548049 Logo
868 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
