Question about Sanyo Xacti VPC-T700 Digital Camera
It looks like a pair of blinds are in front of my flasher
When i take a picture it literally looks like you are looking through a set of blinds. the screen does not show this as you are taking the picture. When you look at the picture you took this appears on screen
  • 53 Answers
It is a problem with the image sensor and is common in point & shoot digital cameras, especially a less trusted brand as Sanyo. Your best action would be to have it repaired or purchase a new camera.
Posted on Jan 16, 2009
Why do my pictures display with lines across them? It looks like window blinds :(
Hi dear!
1. If you see like window blind on LCD when you camera switch on at camera mode. Check one more thing, press menu botton. You still see like window blind on LCD. and then you have defective LCD unit. Otherwise, you have shutter blades (not dust cover blades in front of lens) defect inside of lens unit assembly.
If LCD defect will be very inexpensive service and easy, otherwise, you bring to local repair shop. (very easy problem)
If Actual picture come out like window blind image,
then I want you load to computer and open the file.
You still see like window blind image. then 200% is the shutter blades not working properly inside of lens unit. Bring to local repair shop unless you are not able. Then I can give a little monkey job! using a tooth brush!
Hope You Luck! A Professional Camera Clinic Guy!
Apr 11, 2015 | Nikon COOLPIX Cameras
Turn signals dont work on 1993 skylark. all bulbs are good. hazard lights blink fine. turnsignal dash light stays green and doesnt blink
There are 2 separate flasher relays. 1 for the turn signals and one for the hazards. I believe you have a bad flasher relay for the turn signals. The location of that is in the front seating area on the drivers side, under the dash on the drivers side of the steering column, mounted on support bracket. I provided a picture of what it should kind of look like although the picture I gave you is an aftermarket one so the color and such may be a little different but will look the same. Don't get it mixed up with the hazard relay which is located in the front seating area on the drivers side under the dash above the kick pane lmounted on top of the convenience. I am almost 100 percent sure the flasher and hazard relay are the same so if you want to just swap them out in order to have turn signals that should work. You won't have hazards however. I hope this helps you and good luck.
May 07, 2011 | 1993 Buick Skylark
Where is the fuse flasher located in a 1987 Volvo DL? I was told that this was how to resolve the problem of my fuses for the turn signals which keep on blowing the 8A fuse. I was also told by a parts...
The flasher for your car is located in the front seating area, center, under dash, mounted in front driver side of console. Now I'm not much of a Volvo person but I am a Ford electronics specialist and I'm taking an educated guess that this is not your problem but I could be wrong. A flasher in most cases will not short and I believe you may be looking at a wiring problem but again it's a Volvo and could be wrong. It's just the concept either Ford or Volvo is the same and I am just going by my experience in auto repair. I believe the one for the turn signals will be the square one. I gave you a picture of what both of them look like. The round one only has 2 terminals as I gave a picture of that as well. I hope this helps you a lttle at least and good luck.
Mar 28, 2011 | 1987 Volvo 240
2006 Ram 2500 Diesel. Driver side front and
look for some thing else. most likely a fuse. take a look under the hood there should be a main fuse junction box 8 x 10-12 inches rectangular neer or around the battery.goog luck..
Nov 13, 2009 | 2006 Dodge Ram 2500
Pictures look as though they have blinds across them
The CCD (image sensor) is either defective or damaged. This is usually a problem with cameras that are about 3 or more years old. I don't know what make/model camera you have but this issue is well documented. Here's a link to some of the explanations http://www.imaging-resource.com/badccds.html
Mar 16, 2009 | General Electric A730 Digital Camera
Pictures look like view through a venetian blind
i think the grid lines have been enabled.
and so disable it to having the problem solved
Apr 29, 2008 | Olympus SP-350 Digital Camera
My camera is blind
It is actually ccd problem.its generally due to mishandling of camera.and it repairable but bit costly.
Jan 25, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Picture problem
If you're having like a bright picture with venetian blinds, you could try the steps below:
POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
MASTER RESET
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Scroll down and look for RESET
- Press right button so you could see YES or NO
- Select YES
- Press MENU button
- Turn off camera for a few seconds so that
settings will be refreshed
* If it still does not work, call the Manufacturer so they
could tell you how to send camera for repair.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Sanyo Xacti VPC-T700 Digital Camera Logo
117 people viewed this question
Top Sanyo Cameras Experts
Tony
teddyboy
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
