Question about Apple iPod nano
Change the languague dispaly in the ipod nano 4g
I pressed the menu and middle button for more than 6 secs and i got the apple symbol but the language haven't changed to english except podcast in menu list
After charging it fully i fixed it
Posted on Jan 16, 2009
My ipod nano is a few years old, i just found it but i forgot the password that i used to have. when i plug it into the computer nothing pops up.
You can reset yor ipod by switching the hold button on and then off.
After that you press the menu button and the middle button simultaneously for 6-10 sec untill the apple logo shows. It might be necessary to repeat it.
Aug 17, 2011 | Apple iPod nano
I have a Ipod Nano 4th generation that my son has put a screen lock on it and he has forgotten the combination number. Now we can't access the main menu, it just comes up with a picture of a paddock and a...
What you can do for that Lisa is you can press and hold the middle button and the top that says menu. Hold those until you see an apple symbol then you'll need to press and hold the middle button and the bottom button that has the play/pause symbols on it.
Oct 27, 2009 | Apple iPod nano
My ipod nano is stuck on language selection and does not let me scroll or do anything
hold the center button and the menu button till it shows the Apple symbol then let go and it should reset..if not plug it into a computer and use the reset on the iTunes
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
How to get my language back to english
Select your language.
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
Ipod nano 4G
Reset iPod nano
(if your iPod nano isn’t
responding)
Set the Hold switch to Hold and turn it off again. Press the Menu
and Center buttons at the same time for about 6 seconds, until the
Apple logo appears.
May 22, 2008 | Apple iPod nano
Changed language to french!
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
Feb 09, 2008 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Frozen screen, nano 2 gb
press and hold both the menu and select (middle) buttons for around 10 sec until the apple logo appears... similar to ctrl-alt-del
Nov 06, 2007 | Apple iPod nano
Apple iPod nano Logo
35 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
