Question about Whirlpool Refrigerators
Water in freezer
I have a top freezer without an ice maker. Water is coming from somewhere and freezing - sometimes 4" thick before I chip it out. Water also drips down into the refridgerator.
  • tygers1984 Jan 15, 2009
    makes perfect sense! would the plugs just fall out?
  • tygers1984 Jan 23, 2009
    Turns out that the problem with my refridgerator was a clogged drain in the freezer. It was flushed out and all is well now.
    President:
  • 1,214 Answers
Most refrigerators today are ice maker ready. If the plugs that were installed in the cabinet and freezer compartment that are used to plug the "ice-maker ready" holes are removed, then moisture seeks it's way into the freezer and freezes.
You will need to replace the plugs to prevent this from happening. Do not use tape to cover the holes as most tapes are not watertite. You should be bale to find replacement plugs at your nearest home center, or from the manufacturer of the refrigerator.
Posted on Jan 15, 2009
  • Mark Egan Jan 15, 2009
    Depends. If they were incorrectly sized at the factory they would. If someone got too aggressive in cleaning the refrigerator, they may have been removed and not replaced. If someone planned to put an icemaker in and didn't, they could be missing. Who knows.
    You also will want to check that the seals where the refrigerant lines enter the cabinet have not been compromised in any way. Moisture in the air seeks the nice dry environment of inside the refrigerator. Not only are you getting ice build up in the freezer, it wastes energy and makes your refer work harder.
  • Mark Egan Jan 23, 2009
    Well,
    I may not have hit the answer, which was based on your description of the problem, but at least you found the problem. I didn't think about the drain for the defrost.
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
Water in bottom of freezer it becomes a inch thick freezer door will not open model RFABWP
Check you ice maker. If the cubes aren't freezing the water will continue to fill the I e maker running down to the bottom and then freeze.
Nov 04, 2013 | Samsung Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Jul 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
78 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
