Question about Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind
What do i do with the third wire
Why we do have a third wire Blue on a leviton programmable timer . I belived that it is for the neutral . am i wright 6
  • 37 Answers
You do need a neutral for a timer switch, that is the white wire coming off the timer. The black wire is for the hot wire coming into the box, and the blue wire is the wire going to the light.
Posted on Jan 24, 2009
Leviton programmable timer switch problem
Connect timer white wire to bare ground wire. This will complete circuit to 3 watt timer mechanism, and while this action is not 100% code, it will not pose much risk since the wattage is so low.
Copy following link for illustrations and information:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Leviton-timers.html
Aug 05, 2012 | Leviton Electrical Supplies
Hi I have decora 24 hour programmable timer 6124h. Its display seems to be working just fine and I can change the settings on this. But its not turning the load on. Any idea? Much appreciate the help on...
I don't have repair for defective timer.
Check wire nut connection going to load.
Confirm that load is operable and turned on.
See if timer is producing output on blue wire.
Try timer in place of a different switch to see if problem is load or wire going to load, or if timer is defective.
Make sure there are both ON and OFF times programmed.
Check wiring:
Timer blue wire to load.
Timer black wire to hot.
Timer white wire to neutral.
Green to ground.
http://waterheatertimer.org/Leviton-timers-and-manuals.html
Aug 07, 2011 | Leviton 6124H 24 Hour LCD Programmable...
After installing timer, lights flash on and off.
When lights blink, timer is wired wrong.
Error: The white wire is connected with red-or-blue wire instead of connected to neutral.
Timer has 4 wires: green for ground, black for hot, white for neutral, and red-or-blue wire for Load.
Open following link for wiring instructions and illustration:
http://waterheatertimer.org/Programmable.html#wire
Aug 06, 2011 | Leviton 500W - 6512H-W - Alabaster
Leviton 6651 Decora Programmable Electronic Timer. When turned on all lights flicker. checked all connections and all are fine. Also replaced with regular switch and lights work fine.
There are a lot of problems that can affect timer operation.
Call 1-800-824-3005
We can start guessing at causes, and then you try some things, and add a comment with what you've done so the possibilities are narrowed down.
This could be a wiring problem, timer problem, load capacity problems, circuit problem, possibly a noise interference problem.
I would check load requirements and wiring first.
1) Load:
Manual says: DO NOT INSTALL TO CONTROL A RECEPTACLE, FLOURESCENT LIGHTING, A MOTOR, OR A TRANSFORMER OPERATED APPLIANCE.
Some recessed lighting can have transformers.
Try timer in another room on a different load.
2) For single-pole operation, the black and blue wires are used, and yellow wire is capped off.
Try reversing blue and black wires.
Make sure yellow wire is capped off.
3) For 3-way operation, the timer replace one of the 3-way switches.
The other 3-way switch remains in the circuit, but wiring has to be changed on the remaining 3-way.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Solar Leviton 6651 Decora Programmable...
Need wiring diagram
Open following link to identify timer:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6230
Leviton 6200 series timer replaces single-pole switch. Will not work for 3-way or 4-way applications.
Timer has 4 wires: Blue, Black, White, Green
Timer Green to bare copper wire.
Timer Black to Hot wire from breaker.
Timer White to Neutral wire from breaker. Neutral wires are white wires that are twisted together and covered with wire nut pushed to back of box. If box does not have neutrals, connect Timer white to bare ground wire.
Timer Blue to Load wire.
If timer does not work, reverse Timer Black and Timer Blue.
Apr 10, 2011 | Leviton 1000W / 20A 1HP-120V - 6230M-A -...
I have two of these switches and they both are operating incorrectly. I use them to control bathroom fans in two separate bathrooms, but they both act the same. That is, when I push one of the time...
Leviton countdown timers have additional wire that powers internal electronics.
Leviton timers have red-black-white-green wires (or blue-black-white-green wires)
1) Regular single pole switch has 2 insulated wires. One of these wires is Hot from breaker, and the other goes to Load (fan)
2) Timer green wire connects to bare ground as you know.
3) Hot from breaker connects to timer black wire.
4) Load wire connects to timer red (or blue) wire.
5) Located in back of box are white wires that are twisted together and covered with wire nut.
These are Neutral wires. Connect timer white to these wires. This will power timer electronics.
6) If box does not have Neutral wires described above, then connect timer white to bare ground along with timer green wire.
7) Turn power ON and try timer countdown.
If timer does not work, then reverse timer red and timer black wire.
8) If box does not have neutral wires: Image on link below shows similar Intermatic timer:
Image applies ONLY when Neutral is not available.
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 25, 2011 | Leviton 6230M Decora Four Preset...
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
Need instructions to set my timer. Where can I find these?
You posted under Leviton 6124
If this is not your timer, add a comment.
Also see Leviton timers at:
Leviton 6124 manual
http://waterheatertimer.org/images/6124-manual.pdf
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
May 24, 2010 | Leviton 1000W / 20A 1HP-120V - 6230M-I -...
Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind Logo
309 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Tom Chichester
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
