Question about Sport & Outdoor - Others
1994 v max 600 track installation
Just wondering how do i install a track on a v max 6oo skidoo.Need answer for the tension, distance, i need all the info i can get. I never put a track on before. Any help would be great
Thanks Goldie
Scott called my brother and he talked him through it so i don't know how it was done.
Thanks for trying
Posted on Jan 16, 2009
There are no instructions for installing the dart board
to install the dartboard. the bull should be 5feet 8inches from the floor,the distance of the ockey [where you stand and from] from the wall is 7feet 9and a half inches.
Jan 05, 2011 | Sport & Outdoor - Others
My 1996 skidoo is blowing gas/oil out the exhaust
the air/fuel mixture may be too high on the carb.
there are adjustment screws on the carb.
make very small adjustments.
keep in mind that 2stroke engines like yours are supposed to have oil/gas in the exhaust.
you could lean the fuel/oil mix a little if it is a very excessive amount.
Jan 09, 2010 | Sport & Outdoor - Others
Radiator Protector installation issue
You will have to pull the skid frame out and remove the seat.they are probably riveted in place and you will have to drill them out and replace with new rivets,
Oct 23, 2009 | Sport & Outdoor - Others
Suzuki quadmaster 500 4*4 atv 2000 info please
I had the same problem and all i did was remove the primary and secondary clutchs clean them with mag wheel cleaner and installed a new belt works good now.
Oct 04, 2009 | Sport & Outdoor - Others
I want to buy this pop up camper but the wiffel tree is broke i was wondering how hard it is to fix it and how
It is not difficult however, it may not be broken. First, verify all the pins in the crank linkage are not sheared and thus not turning the wiffle screw. There is on not visible from the outside. Under the camper is a rectangular tube usually mounted between the 2nd and 3rd crossmember. It is just a cover. Remove the cover and near the front is the probable culprit. Just turn the crank and look to see if the wiffle tree screw is turning.
If the handle won't turn or is very hard to turn, the wiffle tree is likely bad. The four cables are attached with welded closed eye-bolts. Just back of the nuts and remove them keeping track of where they go and how much exposed thread is showing. This is the adjustment for the cables to ensure even lifting. On the front the 2nd crossmember is a thrust bearing under a small rectangular cover. Remove the cover, seperate the crank linkage rods and remove the bearing and it's spacer as a set. Pull the wiffle tree screw with the bar the eye-bolts were attached to, forward. It may need some persuasian but it is just a slip fit in the rear and will come forward to remove it. Install new one in reverse order.
Sep 24, 2009 | Coleman Campers Grill
Not sure how to replace the belt in my MTD, Wards snowblower
Remove the housing with the machine off
The idler pulley is designed to push up against the outside of the belt between the drive and motor pulleys when disegaged the belt should look like a loop like a race track
engage the blade clutch and watch to see if it presses up against the drive pully and the motor pulley
their should be a spring attached to the idler arm and i believe the new belt is dragging a little
you should be able to move the belt with your hands ( it should slip freely) rod is engaged or it pulls the idler away
Either a spring causes tension when the rod is engaged or it pulls the idler away
Keep working with it until it is free you may have an adjustment on the spring tension or the linkage rod has an adjustment
I am sure you can do this without an diagram good luck
Nov 18, 2008 | Sport & Outdoor - Others
Pulley system "off track" inside main frame of 2005 boflex revolution
I had same problem. I fixed it by taking plastic sides off using a long phillips head screwdriver. Jay, you don't have to take the sides off to fix your problem. The sides come off only to untangle and rewind cables on pulleys. Pull the cables all the way out. Have a helper pull out and keep holding out the tension knob This is shown at the bottom of page nine in the manual. With someone holding the tension knob out turn the large pully located beneith the tension knob CLOCKWISE! I screwed mine up by turning it counter-clockwise. This winds the handle to the top and if you start with all the cable pulled off the pully, the cable should then wind itself nicely back onto the pully. Once the handle is all the way up, with the round ball on the cable jammed up against the pully, then and only then let go of the tension knob and let it fall back into place. If the handle falls down a few inches repeat this proceedure but push lower pully a bit harder and try to turn tension knob, while it is pulled out, in the opposite direction and it will then click into place one notch tighter and should hold the black ball on the cable firmly against the pulley. Let me know if this was helpful.
Adam
Oct 21, 2008 | Bowflex Revolution Home Gym
Sport & Outdoor - Others Logo
76 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
