Question about SanDisk Sansa e260 MP3 Player
Songs disappearing / "snow" pattern on screen, etc.
About a month ago my player began, of its own accord, gradually deleting most, but not all of my files, totaling about 3gb. Unfortunately, the files were apparently still present, as the disk capacity filled did not change. Nonetheless, the player did not recognize the presence of the files and neither did rhapsody, so I could not delete or play them. After this, when I tried to add files to the player, the error message stating that the file type was not supported appeared. However, this evening, about 2 weeks since last I connected the device to my PC, the error did not appear, and aside from the 3gb of wasted memory, everything appeared to be in working order as I deleted and replaced the remaining 1gb of files. That was, until I disconnected it, and was faced with the dreadful sight of a cascading pattern of black, white, and green pixels. For now, I think I'll remove the battery and replace it to see if i can concur the snowy screen of death, but can anyone aid me in the face of my other problems or that one should it persist?
    Problem Solver:
  • 4 Answers
You can probably ( because I have the same problem) manually open "My Computer" then go in the player and delete all the songs that do not show up, so I think the space will go back, then resynch all the songs back on.
I'm going to try this later.
Posted on Apr 18, 2009
  • 8,596 Answers
Make sure your Rhapsody sub is up to date, and then resync the files
Posted on May 24, 2008
SOURCE:
Phillips 8 GB Go Gear
First thing I would do is try to do a hard reset which means removing all power sources such as the battery and leaving it sit for an hour. If it still doesn't work from there, there may be bigger problems. Let me know how this first option goes
thanks
May 04, 2008 | Philips GoGear HDD1830 MP3 Player
I cannot delete files from my philips gogear ariaz 16gb as it says write protected and when i change to msc to connect to computer so i can manage my folders, it automatically changes to mtp. also my files...
Hi maryseppanen
You can delet you files this way...the other problems may go away after you do this
BE SURE NOT TO DELETE YOUR FIRWARE, ONLY THE SONGS,FILES,ETC.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 16, 2011 | Philips GOGEAR SA6045 MP3 Player
I accidently went to settings and went to format and presses yes and it deleted everything i had. It happened like 6 months ago. Over the 6 months i have started over with putting songs on it and...
Unfortunately, you have likely overwritten the old songs by copying new songs.
One free product worth trying is Recuva (http://www.piriform.com/download)
Download and install Recuva, plug the mp3 player into your computer, and see what can be recovered. Even if you can see some of your old songs they might be corrupted so make sure to listen to them.
I hope this has been informative.
Mar 07, 2011 | SanDisk Sansa e250 MP3 Player
Songs will not transfer to E260
Make sure the songs that you put on are in a format compatible with your player.
If they are not compatible they will not show on the screen or play....
May 06, 2009 | SanDisk Sansa e260 MP3 Player
Randomly deleted songs and cannot upload more
Get the latest firmware upgrade from Sandisk's website to be on the safe side, but I'm thinking that your song licenses expired. Convert all of your songs to mp3 format, and you will not have these kinds of problems.
Jul 06, 2008 | SanDisk Sansa e260 MP3 Player
Deleting songs
I found I had to wait a bit for the deleted songs to actually commit on the MP3 player.  Moreover you might have to 'empty recycle bin' or trash or whatever to get it to happen...and wait a bit for this to be communicated over.
  It sounds like you want to verify that the songs are there and copy them back to your PC, though.  They shouldn't have disappeared from the PC....
Jun 15, 2008 | SanDisk Sansa e260 MP3 Player
If you clicked "yes" to an Update for your device, then all your songs have been wiped. Firmware Upgrades and Repairs (whether performed knowingly or unknowingly), will delete all songs from your GoGear.
Alternatively, when you have automatic synchronization set up for Windows Media Player, then re-syncing to the device when the songs don't exist on your computer will also cause the GoGear to be wiped. It's a feature of WMP that I don't like.
-Tha Mp3 Doctor
Dec 25, 2007 | Philips GoGear HDD1830 MP3 Player
Bad tracks won't delete
Have you tried updating the firmware. Even if it is the lastest edition, download the firmware manually and run the software. Then format in Windows Media player. Best Regards Keith
Jan 27, 2007 | SanDisk Sansa e260 MP3 Player
Help!
Well, i'm having problems with my Sansa c140 also, but with this problem I think I can help, hook your mp3 player into your computer, than delete all the songs, and simply put them all back on, and if that doesn't work, than repost.
Nov 30, 2006 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
