Question about Sharp AL 1631 Copier
Sharp Al1340 copier/Printer drum light blinking I realize i need to change the drum but meanwhile i woould like to continue to use it for afew moore weeks. Is it possible. I need a drum change code to bypass. Tahnks
  • nazeersaleem Jan 17, 2009
    Hi
    claudiomm
    You Rock
    Yes it worked
    You convinced me to sign up for your service
    Thanks and good Luck
    Problem Solver:
  • 10 Answers
Enter C(key) Auto (key) C (key) Auto (key)  so the panel power off. Press number copiers 24 and press print key, press number copiers 07 and press print again. Click C (key)  4 times. Now lamp drum  light on with + 18000 copiers. Good Luck!
Posted on Jan 17, 2009
Warning light is ON for drum AL1340 does it have to be replaced or does it need cleaning?
This means that the default set meter count is due and sometimes the copier stops at this level if it is set so. Please check if the copies are coming out clean and clear as sometimes it may display drum sign with as low count as 5000 copies if set so whereas it can even reach 50,000 copies or higher. If okay , just do not replace it and concentrate on how to clear it. Key in this ( C Auto C Auto) in this order and enter (24 press copy key, enter 7 press copy key). This clears the drum sign and you are relieved.
Jan 27, 2011 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Hp deskjet 1513 all in one
Great you changed the toner cartridges but you may also need to do the following as well.
Imaging drum is low Light pattern c00189128.jpg Description The imaging-drum light is on. The printer continues to print without any action required until the imaging drum is empty. Action Order a new imaging drum. Have a good day
Jun 18, 2009 | HP Office Equipment & Supplies
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Copier drum reset code
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Jan 03, 2009 | Office Equipment & Supplies
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Drum replacement
simulation 24 7 will clear the drum counter
Sep 25, 2008 | Sharp AL-1530CS All-In-One Laser Printer
Sharp al1340 copier won't copy
those dots mean toner, when they blink it's empty. replace the toner cartridge. open the front door and pull it out. pull the seal on the new toner and slide it in. shut the door. that was easy! Good Luck!
Sep 19, 2008 | Sharp AL-1641CS Laser Digital Copier
Blinking light
H4 is a fuser error, check the continuity of the fuser lamp.
Aug 27, 2007 | Sharp AL-1217 Copier
Sharp AL 1631 Copier Logo
108 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
