Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen mode sonyvega kd-34xbr970 screen mode will not gointo normal mode. when switching through different screens, the tv will not allow me to select normal mode. any suggestions?
  • 3 Answers
Unplug the tv for about 20 minutes. If this don't solve repost.
Posted on Sep 25, 2007
SOURCE:
Picture is very dark.
Sounds like the screen voltage has been gone very low than normal. This might happen, if the CRT base socket have any damage. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 21, 2014 | Sony WEGA KD-34XBR970 34" TV
How do i switch from wide screen to normal screen on my Bush btv663dvdsil using my sky remote which is coded for my tv
Hi there
On your remote there should be a "adjustment" button, push that
and on the screen appears a picture of the different ways you can adjust your screen and choose accordingly..
good luckkolbrun
Jun 10, 2012 | Televison & Video
Tv sony vega mod kd-32es170 solo intenta arrancar led verde se keda ensendido yel rojo parpadeando ya le cambie mcz3001db ysige igual me podrian dar agunos consejos
tiene malo el ic que controla el alto voltage , este ic esta localisado serca del flyback ( transformador de alto voltage) # de parte mcz3001d , alo mejor el que esta el tv termina con el letra b , reemplace este ic y el tv funcionara ,
Dec 23, 2010 | Sony WEGA KD-34XBR970 34" TV
My packard bell monitor keeps presenting a blank screen. When the computer is turned on, it starts up as normal but then just after the MS screen appears, it turns off and won't show anything on the...
Try this for starters. Shut down the computer like you normally do. Next turn it on and while its booting up press the F8 key(keep tapping it). You should get a menu and on that menu, one of the choices is Safe mode. Select it and press enter. This will boot your computer into a Diagnostic mode where you can troubleshoot hardware software and windows problem in general. If you successfully get into safe mode answer yes to the question it asks and then goto your Device manager..you can get there by rightclicking the mycomputer icon and select properties from the drop down menu then select the Hardware tab on top.and click DEVICE MANAGER. In this screen look for your display adapter..higlight your graphics adapter and right click...then select uninstall...now reboot your computer normally this time dont press the f8 key..gointo WIndows normally. This should reinstall your graphics card and possibly fix the problem.
Jun 17, 2010 | Packard Bell FT500 15" LCD Monitor
Sony LCD cutting off image when hi-def cable hooked up.
This will happen invariably. Depends on the nature of the signal that is being received. Some will fill entire screen, others will not.
Just go with the flow - tv is operating normally.
Aug 23, 2017 | Sony WEGA KD-34XBR970 34" TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
