Question about Visioneer OneTouch 9220 USB Color Scanner
Scanner says it is lock, but it isn't
I have a Visioneer 9220 scanner and when I try to scan I get a message that it is lock and to unlock it.
I have release the scan lock on the bottom of the scanner, but still keep getting this message an it won't copmplete the scan process.
  • Jeremy2112 Mar 25, 2009
    "Scanner says it is lock, but it isn't"
  • MR KLEEN May 06, 2009
    Scanner says it is locked and is not. I have used it once and paid nearly 200.00 for it new. When I begin to scan it jogs back and forth 2-3 times about 1/4 of an inch and stops. I get a message to "UNLOCK THE SCANNER". I have mechanically unlocked it / downloaded the latest driver (twice) / checked the ac adapter to make sure it is correct / plugged it directly in to the wall / AND I opened it up, advanced the light bar to the end of travel and plugged it back in. It responded by returning to it's "home" position smoothly and accurately and still refuses to scan when prompted.
    WHAT NEXT???
  • 3 Answers
I had the same problem. The scanner car is stuck on the travel rail. Disconnect the scanner and remove the top. Turn over and remove 4 screws holding top to bopttom body. Turn right side up and push in very hard on the lower riight side of body to release snap in holding top to bottom. There are four snaps, one at each corner of scanner. Do the two rear snaps next. Then the left front should slip off. Unfold top toward front so as not to pull butoon wires out of track in bottom body. Clean 1/4" rail at rear of scanner and apply small amount of vaseline. Move car by turning gears at left rear to get to all of the rail. Reassemble. Happy scanning.
Posted on Sep 19, 2009
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
I am unable to scan in Onetouch 9220 after I unlock the button.
Look for the fiber strip along the bottom of the scanner inside the glass. Clean it and the mirror-like thing on the carriage above it. These things work together to encode and decode. Dirt drives them nuts.
May 24, 2010 | Visioneer OneTouch 9220 USB Color Scanner
How to unlock the scanner
Shut down system and let it rest for a while. When restarted, it worked. ???
Mar 31, 2009 | Visioneer OneTouch 9220 Flatbed Scanner
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
Feb 05, 2009 | Visioneer OneTouch 8600 Flatbed Scanner
Visioneer 9000 Scanner Unlocked ????
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
May 26, 2008 | Visioneer OneTouch 9000 Flatbed Scanner
Visioneer 9220 scans red
The scanner bulb is getting to hot. Check power adapter voltage output or replace if is getting to hot
Apr 08, 2008 | Visioneer OneTouch 9220 USB Color Scanner
My scanner does not scan properly
time for a new scanner. these are cheap units and sounds like your lamp is going.
Jan 13, 2008 | Visioneer OneTouch 9220 USB Color Scanner
237 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Sanath Kumar V
Clive Gray
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
