Question about Electrical Supplies
I have a honeywell relay and i need to know what screws go to what. r8226b
  • bob collins
    bob collins May 11, 2010
    What is it being used for?
  • 2,559 Answers
Here is what you need.
Please rate this fixya
Posted on Jan 27, 2009
My Aquastat Relay is not sending power to my oil furnace burner
tap on it with a plastic screw driver if it works shut down system ac spray sys and relay wioth isoprople achohol manually moving relay 2 clean contacts,let dry or use a dryer as achahol as its flameable try again!! mine is doing the same thing gonna clean it in am as im out of achahol. let me know if works! mike
Dec 29, 2012 | Honeywell L8148A1017 Aquastat Relay...
Well my furnace wont turn on at all i got power to the aquastat "honeywell L8148A1017" but no power coming out of the b1 b2 "burrner outs on the board at all but i hear the click in the...
the relay on the aquastat is probably bad ( contacts ) try actuating the relay with a screw driver to see if it engages the unit. if it does theres your problem new aquastat
May 09, 2017 | Honeywell Heating & Cooling
I have a Honeywell Thermostat. I don't know the model number, but it states "replace battery" and no longer lights up. The problem is I don't know how to remove the cover. Please advise
Jan 05, 2011 | Honeywell Programmable Thermostat Heater
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
or this one...
one of those should be pretty much like yours...
May 06, 2010 | Carrier 38CKC036 Air Conditioner
I'm assuming that this is a portable heater. If not let me know. If it is it sounds like the heating coil is bad or the relay which turns on the heat is not working. TU probably means turn up the thermostat. I guess you could try that but it seems pretty obvious. Let me know how you make out.
Feb 10, 2010 | Honeywell Programmable Thermostat Heater
Honeywell rth221 wiring question
The unit has a relay that is opened and closed by the house thermostat. There should be a small brown covered wire... These go to the 'primary' side of the relay (the part that carries current through the relay coil).
One side of the secondary part of the relay (the part with the heavy contacts) are internally connected to the compressor and fan circuit. The other side, the one with the terminal screws, is for connection to the power lines. In a 220V circuit, it makes no difference which of the two wires you connect to which terminal.
The bare wire coming from your house wiring is to ground the unit (Usually a green screw). Hope this helps.
Aug 21, 2009 | Weather King 10AJA2501AH Air Conditioner
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Honeywell HE440A steam power humidifier
Honeywell has had lots of problems with this humidifier. They are coming out with a completely redesigned steam humidifier that will be available in a month or two. If you know who installed it (through equipment stickers and such) you can probably get them to swap your old trouble prone unit for the new design for just the labor. If they won't, then push them to talk with their Honeywell distributor about it.
The problem is most likely a stuck float in the humidifier. There are two floats that run up and down. One that tells it when to add water, and one that is a safety. They both tend to get stuck with mineral deposits.
You can fix it by unplugging the humidifier, turning off the water, draining the pan (unscrew the drain on the bottom a few turns), disconnecting the water lines and wires (2 molded plugs and 2 screw terminals-don't worry about if they get swapped). There should be a couple of screws that lock it into the ductwork such that when you remove the screws you can pull the whole unit out to see inside the water tank. Then just clean everything out well and put it back together in the same order.
You really do want Honeywell to get you a new humidifier though.
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
Honeywell digital thermostat won't turn off ac.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode. If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician. If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
Sep 11, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Electrical Supplies Logo
206 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
