Question about Hawking HWREG1 Repeater
Can't connect to HWREG1 with mac
I dont know where to input the IP,Subnet or gateway!?!
can some1 please give a full step guide so i can actually understand what to do
thanks
  • skinny_jeans Jan 15, 2009
    when i enter that on my internet search bar it doesn't load :S
  • abode Apr 02, 2009
    Manual says
    192.168.1.235
    Admin
    1234
    But still doesn't load control panel interface in a browser FireFox or Safari.
Instead of DHCP choose "Manually"
Enter an IP address of 192.168.1.2
Use a subnet mask of 255.255.255.0
Then enter 192.168.1.235 into your web browser
Log in with: admin and a pw of 1234
Posted on Jun 30, 2009
    Guru:
  • 1,049 Answers
The Hawking Unit uses http://192.168.1.250 as the default IP, the user name: admin and no password. This should work on any platform.
Posted on Jan 15, 2009
  • NA NA
    NA NA Jan 16, 2009
    Are you using Safari? You would need to use IE, Opera, or Firefox. Also do a hard reset and make sure there is not any odd configuration on the router already.
Where can I find the IP address on the XBox 360
If you know your router's IP address, then here are the steps:
If you still need assistance, feel free to post additional questions.
To set your Xbox 360 console's IP settings
  1. On your console, press the Guide button on your controller, go to Settings, and select System Settings.
  2. Select Network Settings.
  3. Select WiredNetwork or the name of your wireless network, if you are prompted to do so.
  4. Select Configure Network.
  5. On the Basic Settings tab, select IP Settings.
  6. Select Manual.
  7. Select IP Address.
  8. Enter the unique IP address that you made up, and then select Done.
  9. Select Subnet Mask, enter your computer's subnet mask, and then select Done.
  10. Select Gateway, enter your computer's default gateway, and then select Done.
  11. Select Done.
Apr 10, 2012 | Microsoft Xbox 360 Console System
Kyocera printer hookup to iMac using Ethernet connection
check the network printing settings in the printer, its a problem in the settings somewhere, unless theres a fault somewhere.
Jul 24, 2008 | Kyocera Mita FS 3800 Laser Printer
Connecting to mac
check this guide if u still have any problem let me know & i send u the step by step method
http://static.compusa.com/pdf/hawking-HWREG1-manual.pdf
Jan 15, 2009 | Hawking HWREG1 Repeater
Extender reboots my Netgear router
I would start with stripping ALL security and encryption settings, see if they work with basic IP addressing setup. Verify that the subnet address ranges are the same and that that the same IP schema is used (IPv4 vs IPv6) on both devices. Then make sure that the security settings are complementary to each other and not in conflict (opposite or identical). Then add the pair to the existing network and check antenna connections.
An alternative suggestion would be to install a Yagi type antenna on the Netgear DG834GT. This will give you a very long and useful range. A Yagi antenna can be made rather inexpensively using a coffee can (Google "coffee can Yagi antenna", I suggest the entry from iHacked.com, this gives a good lesson on the antenna and basic concepts).
Nov 16, 2008 | Hawking HWREG1 Repeater
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
Home > Wizard
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Local Only
The problem might be that you have good connection to the router but having connection trouble between your router and the internet.
Try accessing your router by typing your Gateway into the address field of the web browser of your choice.
Then click on WAN (Wide Area Network) and check your external IP Address. Beside it you will find a button that says "Renew".
The loss of connection might be the result of poor router configuration, bad cable connection or ISP (Internet Service Provider) connectivity trouble.
May 27, 2008 | Hawking HWREG1 Repeater
Assign address manually
hmmm....so, how is the IP address NOT working for you? Can't see it from your computer? A bit more detail please..
Mar 15, 2008 | Hawking HWREG1 Repeater
Cant connect to dns server
When attemptin to attach to a wireless router
Either the SSID's match between your router and wireless adapter or your router is unencrypted and is attached to by the default configuration that uses the SSID it finds of an unencrypted network.
Now the two machines can talk to each other
If you request a dynamic IP address from the router it's DHCP can pass to your wireless adapter a various pieces of information including an IP Address, subnet mask, default gateway (the routers address in this case), adn DNS addresses (optional)
If you have static addressing in the wireless adapter you must provide to the wireless adapter a IP Address (NOT in the DHCP range of the router and not matching any other device attacned to the network, the same subnet mask as the router, the gateway address of the router and DNS addresses.
The first three of these allow you to communicate with the roouter and establish connectivity with it.
If the router's lan address is 192.168.0.1 and subnet mask is 255.255.255.0 then all addresses of devices connected to the router lan must begin 192.168.0.?. IF the DHCP server in the router can assign 192.168.0.100 - 192.168.0.149 as dynamic addresses. We can assign 192.168.0.2 - 192.168.0.99 as static IP addresses each to one and only one device. There are more potential static addresses above 192.168.0.149 but we will ignore them for this discussion.
The communication band (A, B, G, N) sable by for the router and wireless adapter must have at least one in common
Both the router and wireless adapter must have encryption set the same (WEP or WPA with the same passphrases and options)
If Mac Filtering is enabled on the router the MAC address of the wireless adapter must be loaded into the routers table of permitted MAC addresses.
If there is an error in the IP Address, Subnet Mask, Default Gateway?, encryption, or Mac Filtering, mismatched bands the wireless connection will fail as indicated with limited or no connectivity.
Even if all that works you still are not assured access to the internet.
The DNS addresses and default gateway are needed to be correct along with all the ISP's interface requirements for the wan or modem side of the router to be able to access the internet as and achieve the expected results such as accessing google.
If you would like to work through this step by step we can get you connected however I cannot see what you are doing and anything you do or change that I don't know about until we are done is likely to confuse the process. Please reply to this message if you wish for me to continue to assist.
Dec 18, 2007 | Computers & Internet
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Hawking HWREG1 Repeater Logo
814 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
