Question about GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer. The hub nut loosens
During the wash cycle, the hub nut that is located under the agitator becomes loose. It must be tightened after each wash.
  • rekez44 Jan 15, 2009
    The color of the label is school bus yellow
    The entire number is 175D5106G009
    Model # WPRE6100GWT
    Serial # VL186841G
    Thanks for the help
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Could you take the front panel off the washer (push in on the spring clips about two inches in from each side at the seam of the front panel and the washer's top) and tell me what the color of the label on the motor is, and what the first few numbers are on that label. The long number that starts with three digits, then a letter, then more digits with probably also one more letter in it ? Also, please list full model and serial number if possible.
  • 1,543 Answers
You do not have a "high torque" motor (which would have required motor replacement along with these other parts).
Install a new hub washer WH2X1199, split ring WH2X1195, and hub nut WH2X1193. Inspect the hub on the inner basket for wear. If it is worn, the entire SS inner basket (WH45X10060) will also have to be replaced to prevent continued problems. If possible, tighten hub nut with torque wrench to 110 ft-lbs. I hope you did not purchase from Sears. (Sears sold machines are sold with NO FACTORY WARRANTY of any kind. For those, GE will tell you to call Sears.) If not from Sears, you may be able to get some assistance from GE customer relations if you need the inner basket. Your machine was manufactured in Nov. 06, so most likely was purchased over one year ago.
Note: If you look at the board on the top portion of the motor, you should see a LED light flashing on the right front side. It should flash about 1 second on, 1 second off (unless motor running, then .5 on, .5 off) Other flashes indicate various problems. To reset code if necessary, unplug motor for at least 15 seconds, then plug in, wait 3-5 seconds, then open and close lid 5 times within next 10 seconds.
If this does not rate a Fix-Ya for you, please don't bother rating, as I don't like to see my score drop after giving this much free advise.
Thanks.
Posted on Jan 17, 2009
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
My agitator quit working and i took the agitator
theres a belt under neith the unit that is activete whats called wig wags. they activate and that is what activaes itt. v
Jan 11, 2009 | GE Profile WPRE6100G Top Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
573 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
