How do i connect my mac to the HWREG1?
i don't know where to put the IP, Subnet and gateway!
can someone tell me a full step guide please because the one that comes with it is just rubbish
i cannot set up my mac to the range extender ? i get static ip problems and the web page that hawking asks you to pull up through 192.168.1.235 doest work. Infact, when i use internet with DHCP i get a totally new address, 10.0.0.2 . with this setting the problem is that the internet works but it also temporarily vanishes , with the wireless still switched on!!
help me please ? i cannot set up my mac to the range extender ? i get static ip problems and the web page that hawking asks you to pull up through 192.168.1.235 doest work. Infact, when i use internet with DHCP i get a totally new address, 10.0.0.2 . with this setting the problem is that the internet works but it also temporarily vanishes , with the wireless still switched on!!
help me please ?
You can't post conmments that contain an email address.
You have to make sure that the I.P. address, Subnet and Default Gateway are set to match the new routers parameters. (i.e.) I.P.: 192.168.1.44 Subnet: 255.255.255.0
Default Gateway: 192.168.1.254 on the old router.
I.P.: 40.11.120.99 Subnet: 255.255.252.0 Default Gateway: 40.11.1.254
As long as the Subnet & Default Gateways and the I.P config is within the scope of the new router, you should be good. Just remember: All PCs/Laptops will have to reconfigured for the printer's new config also.
To release and renew IP address, go to Start > Run. Type in CMD and
press Enter. At the prompt, type in ipconfig and press Enter. This
will display the adapter information such as IP address, Subnet mask,
and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
1.Log into router 2. Verify wireless router name( on the computer) >>> ( on/off) 3.Note router name you are connecting to. 4.. Check the laptop do ipconfig /all to see current IP addresses. 5. Set the laptop up in the router by WEP KEY or MAC address. 6.Note router name you are connecting to. 7. Move the laptop about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly.
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
your connection won`t drop after this.
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them:
-Enter the menu mode by pressing the + button
-Press the + button till you come to the Network Menu.
-Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting.
-Press the + button till you come to IP address then press the Enter button.
- IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button.
-Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu.
- Press the + button till you see Subnet Mask and press the enter button.
- Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu.
- Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again.
-To exit the menu press the On-line button on the printer.
Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go!
Let us know how it goes and please don?t forget to rate this posting.
help me please ?
